Discussing BBK Clutch Quad install question in the 5.0 Mustangs Forum. Hello, I have a 87 5.GO and I purchased a BBK cable/quad. The ...
Old May 1st, 2008, 03:46 PM   #1
Hello,
I have a 87 5.GO and I purchased a BBK cable/quad. The quad has two holes in it. I know the center hole go on the main shaft but the question is: The second hole, does it go on the shaft the stock plastic adjust came off of or does it just sit on top of that shaft?
Thanks for all your help!
Old May 1st, 2008, 09:42 PM   #2
MIGHTYJO3YOUNG's Avatar
1989 mustang Lx
when i installed mine, i just put it on the main shaft using the larger hole then locked with the cotter pin clip. I don't think u need anything from the old one. some one else will probably give u some better info.
Old May 1st, 2008, 10:22 PM   #3
BUGMAN's Avatar
Here ya go!
Ford Mustang Clutch Cable Installation - Clutch Quadrant - Muscle Mustangs & Fast Fords Magazine
You haven't failed until you stop trying.
Old May 3rd, 2008, 11:46 PM   #4
Ok, got it on but it is hard as H... to push in the clutch. I do not believe I will not be able to physically drive the car like this. I believe if I adjust the adjuster a the firewall that set the pedal hight. If I ajust the cable at the fork will that soften the pedal? right now I do not have much slack at the fork end.
Threads Similar to: BBK Clutch Quad install question
BBK longtube install? TIM350 94-95 9 November 8th, 2007 10:05 PM
BBK Clutch quadrant questions. 93'_GT 5.0 Mustangs 3 September 20th, 2007 07:10 PM
install on bbk h pipe dadslx 5.0 Mustangs 12 September 7th, 2007 03:40 PM
Question about my BBK LT's for you BBK guys .. MeZ Exhaust 3 April 9th, 2007 11:35 PM
Would you buy a used shifter and steeda clutch cable,quad.. zerofx150 99-04 5 February 22nd, 2007 12:41 PM
