89 GT
Checking PTV clearance with a hydraulic lifter?
Is there a good way to pump up the lifter without running the car or do I have to find a solid lifter to use? The engine isn't in the car and I want to double check the PTV clearance before I bolt the heads on. I was just thinking about the lifter not being pumped up and giving me a false reading.
you need to use a solid lifter or take an old hydrualic lifter apart and make it a solid lifter.
89 GT
cool thanks
1986 mustang gt convert
take off spring and add bb's to it and it makes a goodcheap solid lifter...
allso a check spring is usefull
Threads Similar to: Checking PTV clearance with a hydraulic lifter?
| Hydraulic Clutch | brad03svt | 99-04 | 10 | April 21st, 2008 02:03 PM |
| How much lift at lifter? | 5literJeff | 5.0 Mustangs | 2 | March 15th, 2007 09:00 PM |
| stuck lifter | whiteboycustom | 5.0 Mustangs | 4 | March 9th, 2007 06:04 PM |
| Lifter Tapping... help? | Stan27 | 99-04 | 11 | February 21st, 2007 12:17 AM |
| Hydraulic Lifters | ssajdowitz | V6 Mustangs | 2 | October 30th, 2006 10:23 PM |
