12.9 @ 105
351 w
I've been thinking about building a 351w short block and I keep hearing about the older blocks being stronger than the newer ones. My question is how much power have you guys seen on the newer ones. And for the moment i'm going to have to run my world product windsor jr. heads with a 58cc combustion chamber. How much compression would I be looking at with a flat top piston.
1988 Mustang LX Turbo
i have 1986 F250 351w in my 87' Hatch and its holding pretty good at 721hp on low boost
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
1989 Mustang LX
10.98@126.7 NA
Using standard bore, 0.00" deck, 4 cc valve relief, .042 head gaskets 58cc chambers will net 11.2-1 compression
Never fast enough.
12.9 @ 105
1989 Mustang LX
10.98@126.7 NA
Depends on the dish size but with the proper timing and high test 11.2 should be streetable.
Never fast enough.
1986 mustang gt convert
standerd deck,and standard bore,flats around 8-9.1 depends on if its stock pistons or not jrs are 58cc heads 1.94-1.6 valves .cam duration has a hand in itto cuz of how long valves are open
1990 LX hatch
1989 Mustang LX
10.98@126.7 NA
+ .020 will drop the cr to around 10.66 to 1. Remember this the static cr.
Never fast enough.
Did you factor in piston to bore volume and cylinder chamfer? That can be significant especially for forged pistons.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
Threads Similar to: 351 w
| 351 | yankeestang | 94-95 | 2 | February 8th, 2008 04:21 PM |
| 351 | mmvi | V6 Mustangs | 17 | November 28th, 2007 07:22 PM |
| 351 | cali 5.0 | 5.0 Mustangs | 5 | October 9th, 2006 09:33 PM |
| 1972 Mustang Conv. BOSS 351 or 351 HO? | 72BOSS351 | Classic Mustangs | 1 | October 8th, 2006 05:12 PM |
