LinkBack (1) | Thread Tools |
#1
Cam with no PTV clearance issues
I just bought a set of trick flow twisted wedge heads w/ scorpion 1.6 rockers, currently I am running MAC l/t 1 3/4 to 3in collectors, prochamber and dumps, GT-40 upper/lower 70mm t/b AFM powerpipe C&L 76mm MAF and 24lb inj. and smog and a/c delete. What is the best cam for my set up w/ a T-5 and a stock short block that wont smash my valves, also will I need diff pushrods?
89 GT
Call Cam Motion for a custom grind, or any other cam company you like. I would also get the lower on the GT-40 ported to match your heads.
#3 | |
With that being said, any of the Trick Flow cams and all of the Comp Cams Xtreme grinds should fit but you will need to check clearance after you install the cam to be sure.
1989 Mustang LX
10.98@126.7 NA
^+1
Never fast enough.
89 GT
Also, the TW heads require 6.700 pushrods.
1986 mustang gt convert
what ya wanna do . check ya ptv see what it is with new heads and start there..nice cruiser,race,street perf.. idle quality....
1990 LX hatch
Custom grind, perferably from Ned "stinky fingers" McWilsonski.
Im looking to build a good street car for right now, I dont care about idle quality in fact the lumpier the better, I have a Dart block punched and stroked to 363 that is gonna get a Kenne Bell, but thats later on down the road, I just want something right now to drive around that can put up some decent numbers, I was looking at the alphabet cams, the TFS ones and the comp ones, I am afraid of having more bark than bite.
fords letter cams are ok but outdated, comp xe cams are great.. get a cam that will complimenet ya forced induction so ya wont need a new cam latter..usually up to about 500 lift and 220"s in duration at 50 are good on street..but again i recommend check ya ptv first ,then ya know for sure ya clearance and what wide range of lift and duration u can have at any time you want a new cam
I had stinky fingers once.....
Im gonna go with custom for the 363, they guy that did the machine work will get me a good one, Im just lookin for something to throw in it now, the only thing ill prolly re use on the 363 is the GT 40 lower. I really appreciate all the feed back haha Im stuck in Japan right now and everyone talks nissan, I miss the sound of my pushrod V8
#12 | |
1987 ford mustang gt
well see when shes done
Why would you use a gt40 intake on a 363 ci stroker? |
yea im stationed here right now, and the GT-40 b/c the KB S/C mounts only to that lower or a stock GT.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/69074-cam-no-ptv-clearance-issues.html
| Cam with no PTV clearance issues | This thread | Refback | May 2nd, 2008 09:03 AM | |
Threads Similar to: Cam with no PTV clearance issues
| Checking PTV clearance with a hydraulic lifter? | fogged306 | 5.0 Mustangs | 4 | May 5th, 2008 12:08 AM |
| Cam Clearance Issue Question | MyGT | 99-04 | 6 | March 14th, 2008 10:44 PM |
| header ground clearance issues | dshep | 99-04 | 11 | September 24th, 2007 06:38 PM |
| P to V clearance | Steves LX | 5.0 Mustangs | 1 | May 2nd, 2007 10:26 PM |
| Clearance issues | Pharoh | V6 Mustangs | 9 | April 22nd, 2007 02:21 PM |
