E6
Old May 2nd, 2008, 12:00 PM   #1
1996 Mustng GT
stangbanger0796 is on a distinguished road
Send a message via AIM to stangbanger0796 Send a message via Yahoo to stangbanger0796
E6
I have a 302 out of an 88 GT and it has the stock E6 heads. Im wanting to get them worked or get some diff ones. What are the stock specs on the E6's (intake, exhaust, cc).
Old May 2nd, 2008, 12:05 PM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
Tiny ports
Old May 2nd, 2008, 12:09 PM   #3
1996 Mustng GT
yeah i already knew that but do you know the exact size
Old May 2nd, 2008, 12:13 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
If it has E6 heads it is not an 88 engine....or at least the heads are not 88 heads.
Old May 2nd, 2008, 12:16 PM   #5
1996 Mustng GT
what should be on them....they guy i bout it from said it had the E6's....im wanting something a lil more....its going in a car that im hoping to hit high 8s in an 1/8 mile
Old May 2nd, 2008, 12:34 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
If everything is original to the car the heads will be E7s and they will be enough to run high 8s in the 1/8 mile. 26x8.5 slicks will put a stock 5 speed fox body in the 8 in the 1/8 mile if you can drive it.
Old May 2nd, 2008, 12:37 PM   #7
1996 Mustng GT
its got the ford racing E303 cam, rpm performer intakes, 600 doulble pumper, 3.73 gear, c-4, and 1800 stall.....so the E7 will be fine?
Old May 2nd, 2008, 01:56 PM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That car should easily run high 8s in the 1/8 with slicks, even with that tight converter.
Old May 2nd, 2008, 08:22 PM   #9
1996 Mustng GT
alright man...thanks
Old May 7th, 2008, 01:08 PM   #10
1986 mustang gt convert
86gtconvert is on a distinguished road
1.78 and 1.45 valves are in the e7 and e6 aalot...by the time u get bigger valves and head work done ya can buy windsor jrs,srs, or a good used set somtimes of alluminum
Old May 10th, 2008, 01:07 PM   #11
1995 Mustang Coupe 3.8l
STREET6 is on a distinguished road
Yeah, it has e7 heads if original. E6 heads aren't as good. If you pull them, check the numbers on them. Also, if they ar e6 heads it's possible they are ported. There is a company that sells ported e6s.
1995 Mustang Coupe. 3.8l Auto. Bought for $800 and it shows. Swapping in 5.0l carbed. T5 Tranny. Goal 325HP.
