Discussing My Stang Wont Start in the 5.0 Mustangs Forum. a few days ago my i was drive my mustang i noticed when i stop ...
Old May 2nd, 2008, 02:18 PM   #1
86gt t-top's Avatar
1986 mustang GT T-top
Unhappy
My Stang Wont Start
a few days ago my i was drive my mustang i noticed when i stop and parked my car and then tried to start it up it the engine would just crank but there was no spark the first few trys but then it would get going after maybe 1 or 2 trys but now my car wont start at all. i tried to see if there was any current going to my distributer and there was noting. So if any got any advice or poniters pleas let me know cause i really dont like drive my other car around (which is a bullit green 95 Ford Tarus) from a cop autinon for $450
so pls send help
Old May 2nd, 2008, 08:52 PM   #2
fogged306's Avatar
89 GT
How did you check your distributer? If you don't have spark, look at the cap and rotor to see if they look worn at the contacts. If so, get a new cap and rotor. Get new plugs and wires while you're at it. If they are already new.. got any friends with mustangs that you could swap coils with? If you swap and it fires right up, you know where your problem is.
Old May 2nd, 2008, 10:54 PM   #3
Vamp89's Avatar
1989 Mustang GT
Might wanna check the control module.
Trick Flow Street Heat,EGR Delete,BBK 70mm t/b,BBK CAI,BBK Adj Reg,BBK 255 Fuel Pump,BBK Shorties,B303 cam,1.7rr,FRPP Pulleys,Pro-M Racing 75mm Mass Air, MSD 6A Ignition-8.5 wires, X-pipe w Flows, T-5
Old May 2nd, 2008, 11:02 PM   #4
fastford3388's Avatar
1989 Mustang GT
14.70@99mph
+1
Especially if its hot outside. thats when they like to fail
- '89 Mustang GT
- '90 Mustang LX
Old May 2nd, 2008, 11:42 PM   #5
fakesaleen's Avatar
It's the pickup coil in the distributer or the module mounted to the side , but because it would not start after it got warmed up i would think the pickup coil
Old May 2nd, 2008, 11:45 PM   #6
JohnC's Avatar
1997 Mustang GT
13.56@102.94
I'd go for that ignition module. My 87 F250 would buck and miss until it would quit at random and not start back up for hours (until the motor cooled down).
1997 Mustang GT
Aluminum Block PI swap & 4R70W to TR3550 swapped.
Best 1/8: 2.04 60ft 8.74@81.85 &
Best 1/4: 2.04 60ft 13.56@102.94
all on stock 245-17's
My Garage
Old May 3rd, 2008, 01:23 AM   #7
ryans88gt's Avatar
+1 on the TFI module.
89 LX 515 hp 497 ftlbs 11.3 @ 125 mph
88 GT 11.4 @ 118
Threads Similar to: My Stang Wont Start
wont start snailstang 96-98 24 August 30th, 2007 10:46 AM
Wont Start 02steedagt 99-04 5 July 30th, 2007 06:33 PM
Need help wont start! myers215 5.0 Mustangs 5 July 12th, 2007 12:47 AM
Wont start.. Intake Modular Mustangs 11 February 22nd, 2007 09:44 PM
wont start still DragonFreak 96-98 3 February 13th, 2007 01:08 PM
