Discussing Just Installed a BBK CAI and I've got Pics in the 5.0 Mustangs Forum. Originally Posted by Vamp89 I put on the BBK Shorties. How do you like them. ...
Old May 2nd, 2008, 04:18 PM   #21
How do you like them. Notice and gains
1989 mustang GT 5.0
Old May 2nd, 2008, 04:18 PM   #22
Vamp89's Avatar
1989 Mustang GT
I'm also going with 3.73s
Trick Flow Street Heat,EGR Delete,BBK 70mm t/b,BBK CAI,BBK Adj Reg,BBK 255 Fuel Pump,BBK Shorties,B303 cam,1.7rr,FRPP Pulleys,Pro-M Racing 75mm Mass Air, MSD 6A Ignition-8.5 wires, X-pipe w Flows, T-5
Old May 2nd, 2008, 04:20 PM   #23
Vamp89's Avatar
1989 Mustang GT
More responsive.
Old May 2nd, 2008, 06:44 PM   #24
jam77's Avatar
1987 Mustang GT
No way that can ruin your engine....Wash yours all you want.
tell me you are not serious?? You can screw it up if you are a complete moran when you do it . Ive cleaned up 3 mustangs and 1 z28 without trouble
Old May 2nd, 2008, 06:51 PM   #25
blakehunter316's Avatar
1989 Mustang GT
First def clean that motor up man lol please before u cant get all that off . and def go with 373s i got them and i still have a first gear only a first gear that snaps ur neck trust me get 373s
vortech s-trim off road h pipe super 40's steeda tri-ax c.a.i. 3.73s subframe cnntrs 255er
Old May 2nd, 2008, 08:37 PM   #26
fogged306's Avatar
89 GT
I was worried about first gear being too short on a 5 speed with 4.10 gears and my friend had them in his. I drove it and it wasn't bad at all... 3.73's will be fine, thats whats going in mine when it gets finished, and those will have even more of a gear than the 4.10's in first, although not by much.
Old May 2nd, 2008, 09:22 PM   #27
ThrashN's Avatar
91 LX 5.0
11.87
3.55s would be a waste. Go with the 3.73s
Penn Mustangs
Old May 3rd, 2008, 10:44 AM   #28
jlaw98gt's Avatar
^^^^rocks acoustic when drunk
thankyou
Old May 3rd, 2008, 02:49 PM   #29
Goblin's Avatar
Secret In The Works
More responsive.
Well ofcourse they're more responsive than the stock manifolds. Lets compare them to a good set of long tubes.
Definition of Fast?
I'd say thats good enough.
NMRA Outlaw 10.5 Season Opener 2008
Photo courtesy of - Yours Truly
Threads Similar to: Just Installed a BBK CAI and I've got Pics
JLT CAI Installed. RAGEman 99-04 10 January 10th, 2008 06:13 PM
CAI installed.... some questions Basics V6 Mustangs 33 October 29th, 2007 01:40 PM
Tuner and CAI Installed! silver2005gt 2005+ 5 March 1st, 2007 09:49 AM
bbk intake installed FastBack71 Modular Mustangs 1 January 8th, 2007 11:02 PM
Just Installed A Mac CAI themav46 V6 Mustangs 10 October 1st, 2006 11:27 PM
