1991 Mustang Lx
Charging Problems?
Got a 91' 5.0 that runs great. Whenever the engine is running above 1ooo rpm's the volt gauge stays around 15. But everytime it idle's whether it's parked or at a stoplight it drops into the red and the lights dim, radio cut's out ect.If I have the battery charged at autozone it will fire up for a couple of days then has to be jumpstarted everytime after that. I had the same problem with my 89' 5.0 . I do have underdrive pully's. Would that make that big of a difference putting just the stock alt. pulley back on?
1992 Lx
11.39@119.24
most people do the underdrive pulleys and dont do the alternator pulley, i didnt do the alternator pulley and my lights still dim, but it never drains my battery enough for the car not to start, time for a 3g upgrade
Based on your statements, I would say that yes, your alternator is not putting out enough power to maintain the battery charged. Swapping the alt pulley back to the standard one would probably solve your problem. If not, and your battery and terminals check out fine, you may need a 3G upgrade.
1986 mustang gt convert
you can get a small set up to go on a stock alt in a fox to make it a one wire set up for about 40.00 which is cheaper then buyin a new 1 wire alt.. place here called start rite electric builders has them i used to have them
13.64@101mph
i had the same problem, wasnt using the alt underdrive pully, turns out the wires from the battery to the alternator were chard and the alternator shit the bed...new alt and wires solved it..
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come |
My 89' does the same thing and i have underdrive pulleys, unless i step on the pedal a few good times before i turn it off it doesnt like to fire back up.
1989 Mustang LX
10.98@126.7 NA
Have Auto Zone test your alternator and battery.
Never fast enough.
Threads Similar to: Charging Problems?
| charging | WilltheThrill | 99-04 | 5 | January 27th, 2008 07:46 PM |
| Help! Charging probs?? | alabamastanger | 5.0 Mustangs | 3 | January 12th, 2008 01:53 PM |
| charging my fox | Black Five 0h | 5.0 Mustangs | 0 | January 1st, 2008 08:09 PM |
| charging help! | pnyboi | 5.0 Mustangs | 3 | May 7th, 2007 07:54 PM |
| Charging Problem... Please Help! | cstmp8r | Audio/Video | 3 | November 13th, 2006 02:47 AM |
