Discussing No oil in valve cover? in the 5.0 Mustangs Forum. Hey guys im new here and i really need some help here. I had broken ...
Old May 3rd, 2008, 01:29 PM   #1
Hey guys im new here and i really need some help here. I had broken a lifter in my mustang not long ago... I replaced the lifter and did all that, i had to adjust that rocker so now its off by a little bit no biggie right. Well i started the car with the valve cover off to see which rocker the ticking was coming from(to see if it was the one i was messing with). Anyways i was expected oil to hit me in the face but to my surprise no oil at all showed up... The only oil up there was the oil that was there when i started working on the car to begin with. What could be the problem guys? When i bought the car about a month or so ago i noticed at idle the oil pressure was VERY low but when i reved past around 2krpm it would shoot way up. Thanks in advance...
Old May 3rd, 2008, 01:36 PM   #2
1985 GT
none yet
Could be anything from a bad oil pump, dirty pickup, trash in the oiling system going to the rockers and pushrods.
Old May 3rd, 2008, 01:41 PM   #3
Alrighty, i just ordered me a high flow oil pump from napa. Even if it doesnt fix the problem i was wanting to put a high flow on it already.
Old May 3rd, 2008, 08:44 PM   #4
make sure you didn't break your oil pump shaft they break very easily...
Old May 3rd, 2008, 09:38 PM   #5
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Why did you order an oil pump and why a high volume? Did you put an oil pressure gauge on the engine? If so, how much pressure did it have? I'd take that high volume pump back and get a stock pump. All a high volume pump is going to do for you is consume additional horsepower, push more oil thru the stock oil system that already has sufficient volume from a stock pump and it will be harder on your pump shaft and distributor.
Just out of curiousity, how long was the car sitting before you started it and how long did you let the car run after you started it?
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow and Harold at Furo Racecraft
http://www.myspace.com/odarrellrules
Old May 3rd, 2008, 09:53 PM   #6
shadowgames81's Avatar
01 GT
had a high volume oil pump in my car and all it did was break the shaft from the pump to the distibutor. I'd think a stock pump and check it like darrell said.
Old May 3rd, 2008, 09:55 PM   #7
01 GT
as far as I know there are many reasons why you could have low pressure. I don't have a ton of experience but once it took a rebuild and the stock pump to fix my prob
Old May 3rd, 2008, 10:42 PM   #8
JBIGBOOTSY's Avatar
1990 LX hatch
If bearings are worn, then the oil pressure won't come up as high as if they were fresh. Bearings are one area where you'll lose some pressure.
Old May 4th, 2008, 07:52 AM   #9
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Yes and this problem that he is having could be as simple as the car sat for a day or two so when he fired it up the oil had to snake its way thru the engine and the rockers are the last place to see oil.
TrAb, oil will not spray you in the face out of the valve cover. It trickles off the rocker arms.
Old May 4th, 2008, 05:42 PM   #10
vfast's Avatar
I also wonder how much clearance he has from the oil pickup to the oil pan floor?
EVERYONE IS ENTITLED TO MY OPINION
v-6's are for kids*L*
Old May 4th, 2008, 08:04 PM   #11
Editor
Goblin's Avatar
The one and only time i ever used a high volume oil pump, i regretted it. I used it with the stock oil pan, and it would constantly drain the pan before the oil had enough time to trickle back into the pan. I ended up burning that pump up because of it.
Just out of curiousity, and no offense to you... but did you actually check to see if the pan even has enough oil in it? If your not seeing any oil feed to heads, its VERY possible the pan is close to empty. Check your oil first to make sure its where it needs to be.
Definition of Fast?
I'd say thats good enough.
NMRA Outlaw 10.5 Season Opener 2008
Photo courtesy of - Yours Truly
Old May 5th, 2008, 03:51 PM   #12
Yes i made sure the oil is right on the full line. Anyways i threw on that new oil pump yesterday did nothing as i was expecting. BUT while cleaning out the sump i found a little metal cap down there. I later found out threw the help of google that it is a plug that goes in the lifter galley, from what others have told me it will let oil bypass the ports for the top of the heads. So im going to check that out tonight.
Old May 5th, 2008, 04:11 PM   #13
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Instead of doing things backwards and wasting time you should really put a pressure gauge on it and see where the oil pressure is at. Like I said in a previous post, oil doesn't "spray out all over the place" when the valve covers are off. My guess is there is nothing wrong with it because if there was a lack of pressure the engine would have failed a long time ago.
Old May 7th, 2008, 01:47 PM   #14
Well i know it isnt getting oil a idle, i sat there and watched for about 5mins no oil came out at ALL... Anyways im putting in the new galley plug tonight...
Old May 7th, 2008, 03:11 PM   #15
ryans88gt's Avatar
yeah, if it is missing a oil galley plug by the back of the intake, that is a poblem...lol
you'll get no oil pressure to the lifters (thus the lifter tick you were hearing and probably the cause of the failed lifter) and thus no oil pressure to the rockers.
89 LX 515 hp 497 ftlbs
88 GT 11.4 @ 118
Old May 7th, 2008, 07:42 PM   #16
Hey does anybody have any pics of where the front galley plugs go, i have the timing cover off and see a couple different holes
Old May 9th, 2008, 03:25 PM   #17
alrighty, took the timing chain off last night and found the hole that needed to be plugged. So i got me the plug and a little jb weld and tapped it right in. Going to get it all back together tonight
Old May 9th, 2008, 05:31 PM   #18
1985 GT
none yet
hv oil pump can run a stock oil pan dry too
Old May 11th, 2008, 10:12 PM   #19
Hey guys got that plug in and put it all back together, its getting oil like it should now. So happy thats all it was. Thanks for the help
Threads Similar to: No oil in valve cover?
Valve cover ? 88mysticgt 5.0 Mustangs 3 April 5th, 2008 10:00 AM
Valve Cover mustang1072 V6 Mustangs 15 March 23rd, 2008 09:30 PM
valve cover gasket terribleonexx88 5.0 Mustangs 5 July 25th, 2007 03:20 PM
leaky valve cover raceruler03 99-04 4 February 18th, 2007 02:33 PM
89 LX pinging from valve cover Steves LX Engine 3 January 3rd, 2007 10:57 PM
