Discussing Mixing Rocker Ratios In One Motor in the 5.0 Mustangs Forum. I noticed some people mix 1.6 with 1.7 ratio roller rockers.. actually Summit ...
Old October 25th, 2006, 09:21 PM   #1
Zak
I noticed some people mix 1.6 with 1.7 ratio roller rockers.. actually Summit carries a set of TrickFlow rockers that is mixed.
I'm pretty sure they use those rockers with single pattern cams such as E303 or Steeda-19 in order to increase the lift of certain valves..
my question is which ones? INTAKE or EXHAUST should have more lift? Let's say for Forced Induction application, particularly.
This must be a CAM-101 thing for the pro's.
Old October 26th, 2006, 08:56 AM   #2
Zak
Come on.. I can't believe nobdoy knows the answer!
I lean towards having more intake lift..
I need somebody's blessings.
Old October 26th, 2006, 01:37 PM   #3
Zippee is my step sister.
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That is all dependent upon what the engine needs and/or what the head flow numbers are. Commonly people tend to put the 1.7s on the exhaust to increase exhaust lift. That is not always the best thing. For example, the cam I had ground for my engine has more lift on the intake side.
Thanks to: Trick Flow, Team Z Motorsports, Total Engine Airflow and Furo Racecraft
Threads Similar to: Mixing Rocker Ratios In One Motor
3.73 4.10 gear ratios SilverGT04 99-04 0 September 20th, 2007 12:09 PM
Gear Ratios dStoltenberg 5.0 Mustangs 15 April 19th, 2007 09:36 PM
Gear Ratios 00RoushV6 V6 Mustangs 16 February 20th, 2007 10:32 PM
mixing gas mu5t4ng 96-98 6 January 6th, 2007 01:34 AM
PI HEADS AND COMPRESSION RATIOS... delgadog Modular Mustangs 1 December 20th, 2006 10:11 PM
