went and bought a taurus fan...
Old May 6th, 2008, 09:32 PM   #1
mxnate116's Avatar
88 mustang GT
mxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the rough
it came out of a SHO and when i got it back and looked at pics on the internet it doesnt look the same. can i just hook up the larger fan and it will be fine?
and does anyone know what the harness coming off the top near the center it for? i planned on taking it off but i was wondering. thanks
Old May 6th, 2008, 10:07 PM   #2
e3sean's Avatar
1988 lx
9.68@142
e3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the rough
iys proly for the temp sensor will that whole shroud fit your raidaitor? if so hook em both up i just hope u have a 130 amp altornator...
<font size=4><b>MILITARY CREW
Old May 6th, 2008, 10:31 PM   #3
mxnate116's Avatar
88 mustang GT
yeah it will fit on the radiator just barely. and i do have a 130 amp alternator.
would shucks have a fan relay kit on hand?
Old May 6th, 2008, 11:42 PM   #4
e3sean's Avatar
1988 lx
9.68@142
just cut the wires that go to the fan motor tie em together put some 10gauge wire going to them from a relay that turns on with the car or hook it up to a temp sensor from autozone they are about $40 and your set. test the wires on a battery to make sure u dont mix it up cause on way the fan will suck and the other way it will blow..
Old May 7th, 2008, 12:47 AM   #5
mxnate116's Avatar
88 mustang GT
is there a wire under the hood i can tap into to switch the relay when the ignition is on?
Old May 7th, 2008, 03:04 AM   #6
1992 Lx
11.39@119.24
tons of wires for that, just whip out the voltmeter
Old May 7th, 2008, 09:18 AM   #7
1986 mustang gt convert
86gtconvert is on a distinguished road
89-93 i think is best year for taurus v6 fans on a stang v8..i had a 92 i think once was great had a high wire and a low wire and ran fine on high for a long time.wire it to ya ignition
Old May 7th, 2008, 07:29 PM   #8
mxnate116's Avatar
88 mustang GT
sweat deaal thanks guys.
also what amp relay should i pick up 40?
Old May 7th, 2008, 07:50 PM   #9
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
I say do it like the real cars hook it direct to the battery and then run a toggle switch to it by the steering wheel
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old May 7th, 2008, 08:21 PM   #10
1983 mustang lx
83fox is on a distinguished road
i second that one, just dont forget to turn it on haha
Old May 7th, 2008, 09:16 PM   #11
mxnate116's Avatar
88 mustang GT
haha yeah i would probably end up just jumping in my car and take off and not remember about the fan till i smelt that wonderful antifreeze smell...
Old May 7th, 2008, 09:33 PM   #12
1983 mustang lx
i did it this winter moving my car into the garage to work on it. packed snow and 351 foxs dont mix very well, especially uphill with no fan on. luckilly the only thing that happened was antifreeze came out of the overflow
Old May 10th, 2008, 01:39 AM   #13
look in A taurus fuse box and see what amp is on ya fan..ust that 1..i ran a 20 on it without anything else and a 30 adding a audio set up(avg radio)
Threads Similar to: went and bought a taurus fan...
Taurus fan vs Mark vlll fan black88 5.0 Mustangs 1 September 20th, 2007 08:57 PM
Help with installing taurus fan in my 88gt black88 5.0 Mustangs 3 September 5th, 2007 05:03 PM
Taurus/Sable fan for a 5.0? BlueOval 5.0 Mustangs 3 July 30th, 2007 07:27 AM
electric fan vs fan clutch hmotes 5.0 Mustangs 8 December 19th, 2006 03:03 AM
