Discussing Looking to get a chip...Any Ideas? in the 5.0 Mustangs Forum. I have a 90 5.0, with a few mods: Trick Flow R upper and ...
Old May 7th, 2008, 04:03 PM   #1
coffey_5.0's Avatar
1990 Mustang GT
I have a 90 5.0, with a few mods: Trick Flow R upper and lower, GT-40P heads, Trick Flow Stage 1 cam, 80MM MAF, 24lbs Injectors, Roller Rockers, Full exhaust system, and either Mallory or MSD ignition system (coming soon). With all that my ECU has a hard time keeping up. What are some opinions on what to go with: SCT Chip, Superchips, JET chip, etc?
Old May 7th, 2008, 04:13 PM   #2
01 Silver GT
sct tuner...
Silver New Edge Gt
5 Speed with Rebuilt Engine
Steeda Catback, UPR o/r X, SLP Loudmouths
Zoom High Performance Racing Clucth
Bullit replica rims, Mach sound system
K&N Air with Silencer Delete
Complete Mirror Tint
steeda mufflers for sale...
Old May 7th, 2008, 04:21 PM   #3
I Touch Myself Sometimes
HMUSN's Avatar
1991 GT
19.83 @ 12mph
he can't buy a tuner because his car is not obd2.
talk to trick tuners .. he can hook you up with a SCT chip.
He is a great tuner.
Originally Posted by White99stang View Post
not a single piece of rubber in my rear end.
Old May 7th, 2008, 04:27 PM   #4
01 Silver GT
oh....didnt know that lol
sry for the wrong info coffey
Silver New Edge Gt
Old May 7th, 2008, 05:31 PM   #5
JBIGBOOTSY's Avatar
1990 LX hatch
No chips are needed.
Old May 7th, 2008, 06:08 PM   #6
ryans88gt's Avatar
Yeah, I agree with jbig, with those limited mods, a chip isn't going to do much, unless there is something wrong with the car that needs to be corrected, like the fuel tables are way off due to a poorly reading MAF or something like that.
I am still running the stock A9L electronics with no problems.
89 LX 515 hp 497 ftlbs
88 GT 11.4 @ 118
Old May 7th, 2008, 10:39 PM   #7
coffey_5.0's Avatar
1990 Mustang GT
Well i'm having problems with the idle. when first started its higher then normal, obviously, but even after its warmed up it will continue to idle high. Oh, it also has 75MM TB. Could this be a possible problem if the time is one tooth off on the distributor? It also takes longer than normal to start, it used to start right away.
Old May 7th, 2008, 11:44 PM   #8
Vamp89's Avatar
1989 Mustang GT
You don't need a chip, just need to take some time and zero in on whats going on. EGR, O2's and what not. JMO
Trick Flow Street Heat,EGR Delete,BBK 70mm t/b,BBK CAI,BBK Adj Reg,BBK 255 Fuel Pump,BBK Shorties,B303 cam,1.7rr,FRPP Pulleys,CnL 73mm Mass Air, MSD 6A Ignition-8.5 wires, X-pipe w Flows, T-5
Old May 7th, 2008, 11:46 PM   #9
mustang
why do you have an r intake on such a mild motor
Old May 8th, 2008, 11:33 AM   #10
coffey_5.0's Avatar
1990 Mustang GT
thats what the previous owner had on it. any opinions on the timing issue?
Old May 9th, 2008, 12:17 PM   #11
coffey_5.0's Avatar
1990 Mustang GT
anyone?
Old May 9th, 2008, 01:05 PM   #12
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Chips are a gimmick. I've yet to see anybody dyno an aftermarket chip and make any horsepower. ADS used to show a gain of 8 horsepower but they had an "octane bar" to put in the distributor that effectively advaced the timing to about 15 degrees base. When tested by an independent party pulling the chip out didn't change the horsepower at all. All the power was gained from timing advance from the octane bar which does nothing more than what you can do yourself by advancing the timing. The only beneficial chip is one that can be programmed (like SCT) that is done on a dyno by someone that knows what they are doing (Kurgan, Post). You will gain power doing it the right way. I see alot of ebay auctions advertising mail order tunes and email tunes. Stay far away from that crap.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow and Harold at Furo Racecraft
http://www.myspace.com/odarrellrules
Old May 9th, 2008, 01:55 PM   #13
ive seen people run 14psi of boost on a stock block with a single setup using stock computer just timming and fuel pressure adjusted and they have ran some pretty nicer numbers. so to me i think your safe...
Old May 9th, 2008, 02:15 PM   #14
ryans88gt's Avatar
A couple of people, Kurgan included, will send a tune by mail, but you have to datalog exactly what he wants to know with a wideband before he'll do it.
88 GT 11.4 @ 118
Old May 9th, 2008, 02:16 PM   #15
ryans88gt's Avatar
Check your timing with a timing light. If you are a gear off on the dizzy, it will run like shit all the time. If you want to check, bump the motor over to top dead center and then pull the distributor cap. the rotor should be pointing at exactly 12 o'clock. If it is a tooth off it will be pointing at like 1 or 11.
As for idle, follow the idle reset in the stickies above.
88 GT 11.4 @ 118
Old May 9th, 2008, 10:41 PM   #16
coffey_5.0's Avatar
1990 Mustang GT
alright sweet thanks, that will save me some dough then.
Old May 11th, 2008, 04:17 PM   #17
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Yeah, datalogging and getting a tune is a bit different then just telling someone what has been done to your car and getting a tune mailed to you.
Old May 11th, 2008, 08:29 PM   #18
HMUSN's Avatar
1991 GT
19.83 @ 12mph
it's a LOT different.
Threads Similar to: Looking to get a chip...Any Ideas?
chip ? finaly03vert 99-04 12 January 13th, 2008 10:46 PM
OK a $20 chip... Come on Timm10221 The Clubhouse 7 October 17th, 2007 12:48 PM
what is the best chip mustangdevil69 Electronics 7 October 4th, 2007 10:19 PM
chip maybe>? speed4goal 5.0 Mustangs 17 January 27th, 2007 04:49 PM
HP Chip mustang1072 V6 Mustangs 14 January 24th, 2007 12:45 PM
