Discussing running hot in the 5.0 Mustangs Forum. I have a 306, stock heads, 10:1 comp. 466. lift cam, Cobra intake, full ...
Old May 8th, 2008, 12:01 AM   #1
running hot
I have a 306, stock heads, 10:1 comp. 466. lift cam, Cobra intake, full exhaust. I put a 195 thermostat in with teh stock belt driven fan. I drove the car for two weeks last year like this. If I remember correctly It sat right in the middle of teh guage I think that is about 200 degrees. Well I just got my car driving again and I put a proform Electric fan in and now it runs between the o and the r on normal and sometimes a little higher.
I searched for the answer and It seems that people say to run a 180 degree therm. I would like to get some responses to my actual situation. It seems that proform fan sucks I quess I need a taurus or mark fan. Which one should I get and should i buy it new or go to a junk yard. I appreciate the help.
Thanks
Jon
1992 Mustang Notchback-306, road race project.
Old May 8th, 2008, 12:53 AM   #2
93hatch's Avatar
1993 Lx
14.097/98.2
get a 180, if you want it to stay under half way get a 165
Foxbodys FTMFW
yay no more centered threads!!!!!!!
Old May 8th, 2008, 01:13 AM   #3
1965 Mustang Fastback
flush radiator? change oil?
Old May 8th, 2008, 01:33 AM   #4
8t6gt's Avatar
1986 Mustang GT
Location: FOUND BWAL! hes now giving hand jobs to all paser bys
Do you have underdrive pulleys
Mine would fuck up the cooling
BUY MY CAR!!!!!
proud member of..CLASSICS OR GTFO!!
Originally Posted by Squints View Post
i'm all for global warming. who needs polar bears anyway?
Old May 8th, 2008, 10:01 AM   #5
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Thanks
Jon
If you have a 195 degree thermostat, its going to run around 195 degrees......
"runs between the o and the r on normal" is a pretty wide open statement that really means nothing as far as temperature wise. It could be 180 degrees or it could be 225 degrees depending on how accurate your gauge is. The only way to know for sure is to check it with an accurate gauge.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow and Harold at Furo Racecraft
http://www.myspace.com/odarrellrules
Old May 10th, 2008, 12:35 AM   #6
1986 mustang gt convert
195 means it starts to pen then,it takes usually 10-15 more gegrees b4 it fully opens... i got a 165 opens and stays around 180and i run around 380-390 fly hp
Old May 10th, 2008, 10:33 AM   #7
1989 lx convertable
11.30
u might want to check to see that the fan is blowing cool air from outside through the radiator and not sucking the hot air from inside the motor and heating the radiator i pulled that one b4
Old May 11th, 2008, 11:06 AM   #8
I looked up that teh stock 195 fully opens at 221 just where it sits about. That is where the stock motors sat. Mine is modified so will be harder to cool. Oh and does that air dam/deflector do anything that sits under teh front bumper? It just seems that there is no good size opening on teh front of the bumper?
Old May 13th, 2008, 11:50 PM   #9
i had a hci, and had a 125 pill of juice on top of 380 fly hp//i ran cool with a v6 taurus fan and a 165 thermo,4.10 gears//.060 over bore in a 1970 block
Threads Similar to: running hot
95 GT Running Very Hot JesusOnIceSkates 94-95 14 November 13th, 2007 04:57 PM
RUNNING HOT!!!!!!! BLACKNIGHT5.0 94-95 37 September 5th, 2007 03:27 PM
running hot on a/c mustanghead 5.0 Mustangs 12 July 17th, 2007 09:18 PM
running hot ttop5.0 5.0 Mustangs 10 July 19th, 2006 11:47 AM
My 93 gt is running hot a little help niggadrew 5.0 Mustangs 16 June 15th, 2006 05:51 PM
