Discussing Pressure in my valve cover!? in the 5.0 Mustangs Forum. Anybody know why Id get a ton of pressure buildup at higher rpms in my ...
Old May 8th, 2008, 10:12 PM   #1
Anybody know why Id get a ton of pressure buildup at higher rpms in my Valve cover (PCV side)? Doesnt happen on the other side, and my PCV is new and check out ok. Could this be rings that arent sealing and at high revs the pressure gets too high? It blows out my valve cover gasket and you hear a "whistling sound" until it idles again. Gets some oil on my intake too. The other side has a breather and seams to be ok. Im stumped.
1964 Falcon Sprint 4 speed
1965 347 Cyclone 4 speed, B/FX clone
1993 Mustang Cobra (red/grey cloth)
Old May 9th, 2008, 12:08 AM   #2
ryans88gt's Avatar
get a new breather
89 LX 515 hp 497 ftlbs
88 GT 11.4 @ 118
Old May 9th, 2008, 12:40 AM   #3
breather tests fine. Any other ideas?
Old May 9th, 2008, 02:12 PM   #4
ryans88gt's Avatar
If your breather works fine, then you have no pressure under the valve cover.
88 GT 11.4 @ 118
Old May 9th, 2008, 04:46 PM   #5
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
Crankcase and inside of valve covers (both sides) are in common atmosphere. Pressure is the same. Ring blow by comes out the bottom of the cylinder into the crankcase.
Never fast enough.
Old May 9th, 2008, 04:52 PM   #6
qwik48r's Avatar
08 GT
sounds like valve blow by.... take a compression reading of the problem bank.
everyone's a gen-ious around here...
08 Black GT 5sp. Hurst.Pypes.Motive.Nitto(wrong kind, and for sale!!).Mobil1
02 GMC Sierra ECSB. TR.Pacesetter.CompCams.Crane.
Richmond.Eaton.K&N.Performabuilt.FlowCrapster. Nelson Tuned!
Old May 9th, 2008, 05:53 PM   #7
ryans88gt's Avatar
IF you had enough blow by, either from rings or valve seals, that a valve cover breather wasn't enough to vent (figure more than 200 cfm), then you would have more serious problems than a leaking valve cover gasket. Like burning 2 quarts of oil a day.
88 GT 11.4 @ 118
Old May 9th, 2008, 05:55 PM   #8
ryans88gt's Avatar
In this case, he has breathers and a PCV, so everything should be at atmospheric pressure or slightly below. The only way to have positive pressure would be if there was so much blow by that the breathers couldn't vent it, if that was the case, there would be a serious problem with more symptoms.
88 GT 11.4 @ 118
Old May 9th, 2008, 09:57 PM   #9
qwik48r's Avatar
08 GT
are you sure your motor isnt constipated?
Old May 10th, 2008, 11:10 AM   #10
I think I found it. I had my aircleaner off that day and the ram air was going directly into the carb unrestricted. At higher speeds, the airpressure was enough that it stopped or disrupted the flow from the PCV valve and caused that bank valve cover to load up with pressure.
And to the smartass who wants to know if my motor is constipated?....No, but I am. To much whiskey and Fritos
Threads Similar to: Pressure in my valve cover!?
Valve cover ? 88mysticgt 5.0 Mustangs 3 April 5th, 2008 10:00 AM
Valve Cover mustang1072 V6 Mustangs 15 March 23rd, 2008 09:30 PM
valve cover painting KenDogg 2005+ 20 March 10th, 2008 09:46 AM
Valve cover options caintcatchmyGT 96-98 21 October 24th, 2007 06:20 PM
leaky valve cover raceruler03 99-04 4 February 18th, 2007 02:33 PM
