Discussing Replacing Front Control arm bushings advice in the 5.0 Mustangs Forum. I want to upgrade my rubber units that are wore out on my 83 convertible ...
Old May 9th, 2008, 05:31 AM   #1
I want to upgrade my rubber units that are wore out on my 83 convertible with the Steeda Offset urethane bushings.
Anyone done these and do you need a press to put them in or can you do it with a vice, hammer your self? Have replaced the springs struts etc., this is the only thing I am unsure of to tackle.
Any advice is appreciated.
Thanks
Old May 9th, 2008, 07:56 AM   #2
tom2000r's Avatar
I never done any on a mustang..but I have on chevelles..I burn them out with a torch,put new bushings in freezer over nite then pound them in with a hammer....I think auto motive machine shops will install them too.you can use propane torch,but do it outside....some use air chisel....
Old May 9th, 2008, 05:48 PM   #3
Thanks, getting them out shouldn't be a problems as I was going to doas you suggested to burn them out, never thought about the freezer trick, will remember that.
I just don't want to distort or damage the bushing, are they pretty tough and can take abit of pounding?
Thanks
Old May 9th, 2008, 08:03 PM   #4
mustang
Please tell me how you are going to burn the metal sleeve out of the front control arm? mine were a pita to get out after i burned the old rubber bushing out.
btw i replaced mine with prothane motion controls poly bushings
you are not going to distort or mess up any polyurethane bushing with a hammer.
Old May 9th, 2008, 09:20 PM   #5
Were you able to just hammer them?
Old May 9th, 2008, 09:26 PM   #6
mustang
I pressed mine in
Threads Similar to: Replacing Front Control arm bushings advice
Control Arm Bushings 89StAngerLX 5.0 Mustangs 8 May 3rd, 2008 12:04 AM
Control Arm Bushings? CMcD 5.0Lx93 5.0 Mustangs 5 August 8th, 2007 12:37 AM
Rear control arm bushings Stangzilla 5.0 Mustangs 7 June 2nd, 2007 12:50 AM
control arm bushings angermgt 5.0 Mustangs 5 May 15th, 2007 07:30 PM
Lower Control Arm Bushings cali 5.0 5.0 Mustangs 3 November 13th, 2006 06:04 AM
