LinkBack (1) | Thread Tools |
#61 |
![]() iTrader: 1 reviews
anybody know what his user name is on here?
Just Another Bolt on GT [IMG]http://i45.tinypic.com/54f5ua.jpg[/IMG] Stock Longblock - 287/276 Low 12s NA! 10s on the spray? |
#62 |
RLY SRS
#63 |
thanks
#64 |
OK dude, you need a 60 mm turbo at best, that will be enough to support 550-600 hp to the wheels.
Second, to stay out of boost during normal driving, you use a bypass style BOV referenced to a vacuum source. So whenever you are not at WOT the boost will be bypassed back to the inlet side. When you open it up the bypass snaps shut (no more vacuum to hold it open) and you have boost.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
#66 |
Why would you have a huge ass cam on a turbo car?
But anyway they are adjustable with a spring. The vacuum reference goes from negative pressure holding the bypass open to positive pressure (under boost) holding it closed under boost. So even if you have no vacuum it would still work in theory, you just need to adjust the spring to the right pressure to hold it open.
#67 |
Hell if i know? I never had a turbo car! But thats how ya learn. asking questions right?
I just know ppl seem to like throwing to large a cam in their cars for some reason.
1986 Mustang GT t-top time piece! |
#68 |
1987 ford mustang gt
well see when shes done
Where they can at least say something is big
#69 |
Usually cams that tighter profiles and less intake/exhaust overlap make more power on turbo cars since the exhaust has a lot of back pressure and no scavenging effect.
The stock EFI cam actually works pretty well in turbo cars.
#70 | |
RIP Justincredible! God Speed
A good 70mm turbo and a stock cam, on pump gas, will easily make more than enough hp to split a stock block.
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster . BIVENS RACE CARS FTMFW!!! |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/70359-turbo-question.html
| turbo question | This thread | Refback | May 10th, 2008 09:00 AM | |
Threads Similar to: turbo question
| Turbo Question.. | J Mac0123 | 99-04 | 21 | March 8th, 2009 01:17 AM |
| Turbo question | GreenFaleen | The Clubhouse | 26 | February 19th, 2008 09:40 PM |
| turbo question | dcrow | 99-04 | 15 | February 3rd, 2008 03:08 AM |
| Turbo is done, got a question for you turbo guru's | Regency 2007 | 2005 - 2010 | 33 | June 26th, 2007 08:46 AM |
| Another Turbo Sc Question???? | FLA Dreadhead | 2005 - 2010 | 3 | February 14th, 2007 01:14 PM |
