Discussing Speedometer and Chiming problem in the 5.0 Mustangs Forum. i dont know if its because it was sitting for a while with it barley ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
i dont know if its because it was sitting for a while with it barley being driven but my Speedometer doesnt work. it slowly goes up. and it hangs at 20mph for a few seconds and then it climbs up slowly and then it bounces around from 40 to 60 mph and then when i slow down it takes a while to go down and then hangs at 20 mph and eventually goes all the way down after i been stopped for a little.
What could be the problem??? and when ever i open my door my Chime goes on. doesnt matter if the lights are on or off or if the keys in the ignition or not. it doesnt shut off until the door is shut. why is it doing that?? its not that big of a deal but it is annoying.
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!! |
take your gauge cluster off the cable is probly just about to fall off the speedo
85 4 banger stanger, it likes to sneeze alot when i hit the gas ![]()
oh great. im sure i need to have this fixed for insp. and my luck ill end up messing the odometer up when i do this.
hypothetically speaking what could happen if i do this and mess up the odemeter and it isnt even or what ever and they suspect milage roll back. thats the last thing i need right now.
1984 GT
13.79@98.99
You won't ruin your odometer but you could break the plastic piece that holds the cable to the speedo. Be very careful removing your instrument cluster. You must squeeze the plastic piece were the cable goes into the speedo. DON'T force it out.
Or if it is loose or seems loose just push it back on. Personally I can't imagine that piece coming out because it is a pain in the but to remove. If it isn't that it could be your speedo gear at the trany. That is an easy fix. jjg
Eibach Sportsline, Mac, Moroso,Comp Cams,PRW roller rockers, and no money left over. |
I was gonna say, i thought mine was the wrong one it was so damn hard to get off and get the new one on....actually sounds like a cluster issue is you have an electronic speedo sender because of the chime issue
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
so it could be that the cable is hanging, or i might need a new speedo gear or a new cable???
oh well. im getting it inspected/Emissions done on it tomorrow. ill let them figure it out.
they wont tell you whats wrong with it theyll just fail you for safety
lol. then he can fix it. if he tells me it has to be fixed then it has to be fixed. ill just tell him to go ahead and do it.
well i just got a call from him and everything passed except the passenger side brake hose needs to be replaced.
i was so afraid it wasnt gonna pass emissions but it passed so im extremly happy.
I have a brand new a.z speedo cable, and with my 4.56 gears, it bounces form 0-30 at first, smooths out, then starts bouncing again. Just so you can see it may not necessarily be the cable, a cable is an inexpensive place to start
Threads Similar to: Speedometer and Chiming problem
| speedometer | Mike73 | Modular Mustangs | 4 | October 27th, 2007 02:49 PM |
| Speedometer | akatagyourit | 2.3 Mustangs | 2 | September 15th, 2007 02:24 AM |
| Speedometer | Arhilion | 96-98 | 8 | May 23rd, 2007 08:36 AM |
| Speedometer. Kmh to mph | Timmano | V6 Mustangs | 7 | May 4th, 2007 12:38 AM |
| Speedometer | 88MustangGT | 5.0 Mustangs | 8 | January 3rd, 2007 08:11 AM |
