True Trac is in...
Old May 11th, 2008, 12:17 PM   #1
1993 GT
13.2@105
1982matthew is on a distinguished road
True Trac is in...
Last night I finished putting in my true trac and today I filled her up with oil and just got back from my test ride aka damn fun ride, and let me tell you.. thank you to everyone that directed me towards getting that rear. So now as long as it holds up I will be a very happy man. I will post picks of the locker and how the pins just sheered off as soon as I can get my gurls camera from her... and now for the technical part. I put 4 quarts of oil in already and it isn't quite full do you guys think I should put more in. It has an aftermarket cover that I am guessing ups the capacity quite a bit.
Old May 11th, 2008, 12:42 PM   #2
ryans88gt's Avatar
Are you using the fill plug on the cover to determine the full level...lol
That fill plug is way too high, pull the plug out of the front of the center section and I bet you have too much oil in it and it will come pouring out.
It's OK, I did the same thing the first time I put a aftermarket diff cover on. The oil will start leaking out of the breather on the passenger side axle tube after awhile.
Old May 11th, 2008, 03:34 PM   #3
1993 GT
13.2@105
stop laughing at me, I know I'm a fool. Will it matter if I have too much in there. I used mobil one and that shit is expensive so I spent an extra 9 bux for nuttin damnit........
Old May 11th, 2008, 04:33 PM   #4
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
It will be better to drain it down to the proper level. Save the gear lube you drain out for topping it off later if needed.
Never fast enough.
Threads Similar to: True Trac is in...
true or not true about cobra and the gt Rear Brake caliper? RanGer498 99-04 15 March 30th, 2008 02:06 AM
Best place to buy Detroit Locker True Trac? PapaSmurf 99-04 13 March 13th, 2008 09:51 PM
Trac Off stanged out V6 Mustangs 22 November 21st, 2006 02:31 PM
Detroit True-Trac ryanhewett466 General Tech 2 August 6th, 2006 09:58 PM
