Discussing Slowest Car In The World (Help) in the 5.0 Mustangs Forum. something is really wrong with my 88 cougar. it has the 5.0(non-ho) ...
Old October 27th, 2006, 02:28 PM   #1
something is really wrong with my 88 cougar. it has the 5.0(non-ho) it has absoulutly no power. its not safe to drive because its sooooo slow. it runs rough and smokes just a litlle bit. the oil is clean, compression test was perfect and i dont loose coolant. so the head gaskets are good. im getting spark, but thats what it sounds like. please help!!!
Old October 27th, 2006, 02:53 PM   #2
soundls like u need to get a new car. :wink
Old October 27th, 2006, 03:05 PM   #3
dr.gonzo's Avatar
if it is smoking I would say the piston rigns and double check your compression. the reason you have no power is probobly due to no compression/or no spark missfire. it also helps if you can if all 8 pistons are actually fireing. is it smoking from the tailpipe or in the engine bay? do you see any oil leaks in the enigine bay? if it is ideling rough check the timing and o2 sen if that is ok then check your computer. if it is like my 88 mustang it should be by the passenger kick panel. give it a tune up or atleast start with the sparkplugs with the right gap and work your way back to the distributor
Old October 27th, 2006, 03:19 PM   #4
plugs/wires are good. rings are good. it also pops out the intake(backfire) while its running.its not a major backfire, but its backfiring. timing is right(timing light says so)lol. im guessin its the o2 sensor.
Old October 27th, 2006, 03:49 PM   #5
Stangzilla's Avatar
No power
Are you checking the timing with the jumper out on the distributor? I think that year has one. I have a 93 Mustang I am not sure about your year someone correct me if I am wrong....
If that dont work get a new ride.... LOL!!
Threads Similar to: Slowest Car In The World (Help)
what in the world? nba1341 The Clubhouse 12 October 13th, 2007 10:53 PM
New to the 5.0 World. WElcome ME :-) tehdwarvenn 5.0 Mustangs 13 September 26th, 2007 08:39 PM
what in the world mustang1072 The Clubhouse 13 March 29th, 2007 01:48 PM
The Only One In The World Stock Multimedia 6 November 16th, 2006 09:12 PM
Just Saying HI To Everyone In The 5.0 World ret27m 5.0 Mustangs 7 September 21st, 2006 10:55 AM
