Holy Dick Castle!
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
Car Dies If It Is Too Hot Out - Ignition Module?
I have an 88 gt with 3.73 gears aod w a single flex fan. when it is 75deg and up if I go 65 mph for about 30min and then get stuck in a traffic jam the car just dies on me. I made the mistake the first time and called a tow truck to take it to the mechanic and abra kadabra the car started the next morning (nice and cold) before this happend I had him bump the timing up a little bit but not much. he said it might be the ignition module so I replaced that with one from autozone and it still dies after a while. he said if I replaced the ignition module myself then there was a chance that I messed with the timing and made it run a little hotter. should I buy a more expensive distributor like from msd or accel? I know someone else had to of had this problem.
11.47@120.58
Is it a spark problem? Have you checked for fire while the car isn't running? It could be the ignition module, getting hot and acting up is the beginning signs of one going out - though it could be other problems. They're fairly inexpensive, maybe $30 I'm guessing... you could always buy it and see if it fixes it.
Holy Dick Castle!
mabey I should go with a more expensive one like in the picture. I havent had a chace to check for spark because I am usually alone when I break down. and only 2 hands its hard to hit the coil and check spark
Fuel pumps in these years were also famous for dying when hot or with low fuel in the tank so it couldn't stay cool enough. Then miraculously come back to life. Listen for the momentary running of the pump when you first flip on the ignition switch right after it dies.
X2...fuel pump relay can even be breaking contact when it heats up enough
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
#7 | |
Holy Dick Castle!
is that the relay by the computer behind the passenger kick panel? I saw a relay that looked like it was just hanging out and plugged into a couple of wires. I thought it was an odd place to put it. why not have all fuses and relays close together. would'nt it be cool to have them right in the center under the arm rest?
95 opalfrost gt
Can you verify that you are or are not getting spark when this happens? Is the fuel pump priming (ie) can you hear it buzz when you click the key? Could possibly be the PIP in the dizzy If you already replaced the TFi I would look their. Have the TFI you installed tested to seeif its any good. good luck
1990 HATCH
12.56@118
I had the same problem. Replaced the coil, and it hasn't died yet.
I really really wish I knew about this 10 years ago when I had my 5.0 had the same thing happend, stalled at a toll, rolled to the side of the road. I did get lucky and a tow truck, drove by picked me up....didn't have to pay for towing just one night storage, it wasn't that bad to be honest, but if I knew all I had to do was cool it off!! I would have then continued on my way.
Mustangs I've owned... but never an SVT it's just my SN here... '88 5.0 LX 5 Speed '89 5.0 GT 5 Speed '87 4CYL Auto '95 5.0 GT AOD Vert. all else were hard tops. |
Fuel relay was under the drivers seat on my 86 gt, probably same place as yours.
Fuel relay is under the drivers seat on that car. Next time the car is hot, turn the key on and listen for the fuel pump to come on for a second or two. If it doesn't, under the hood is the ECC jumper plug. Stick a wire in the bottom right slot in the plug. (I think it's bottom right) Ground the other end of the wire. Flip the key on. That should make the fuel pump run as long as the key is on. If you don't hear the pump...Then it's probably bad.
Threads Similar to: Car Dies If It Is Too Hot Out - Ignition Module?
| control module | 92stang | 5.0 Mustangs | 0 | November 4th, 2007 09:35 PM |
| Windows Module Question.........? | gills99stang | 2005 - 2010 | 14 | July 27th, 2007 02:46 PM |
| ::HELP::location of ignition module on 98 stang v6 | oscardisel | 96-98 | 3 | December 14th, 2006 12:52 AM |
| Ignition control module | flynfalcon | V6 Mustangs | 6 | November 22nd, 2006 04:00 PM |
| Prologixx Performance Module | jerb43 | General Tech | 0 | October 8th, 2006 09:36 PM |
