Leaking Oil
Old May 12th, 2008, 01:13 AM   #1
1965 Mustang Fastback
nba1341 will become famous soon enough
Leaking Oil
Ok so I changed my oil 2 weeks ago and I did not change the oil pan bolt gasket and tightened it up and put my filter on blah blah and added oil.
I noticed I was dripping so I got under there and tightened it 1 half turn and figured ok so it wasnt tight enough it will stop now.
Well found out it was still dripping so I tightened a little more but it still drips so Im not going to try and tighten it anymore because I don't want to overtighten the bolt and ruin my oil pan.
Do you guys think its dripping because I didnt replace the bolts gasket/washer thingy? My current one is plastic which i thought was kind of weird how would that stop oil....
Do you think if i change out the bolt washer/gasket it will fix my problem? (btw no oil leaking from filter thats perfect)
I'm a good boy now.
[COLOR=red][B]slow car club - crew member 7 of 9
[COLOR=White]Mood: Cool :cool:
[/COLOR][/B] [/COLOR]
Old May 12th, 2008, 01:29 AM   #2
1992 Lx
11.39@119.24
probly, my friends a lube tech and they change the gasket on the oil pan bolt on every car they do for that exact reason
Old May 12th, 2008, 01:33 AM   #3
do they hand tighten or machine tighten the bolt?
im scared to overtighten it with my hand....
I'm a good boy now.
Old May 12th, 2008, 01:34 AM   #4
1992 Lx
11.39@119.24
hand tighten, we tighten the shit outa the ones on my fox, with a rachet
Old May 12th, 2008, 01:40 AM   #5
so you tighten it till it wont turn no more by hand?
I'm a good boy now.
Old May 12th, 2008, 01:45 AM   #6
1992 Lx
11.39@119.24
yeah just like, im not conceited, well, i am about some shit, but im strong as fuck, like when your tightening it you can tell if your abouta break something you know what i mean? like tight yes to the point you think your gona break something, no
Old May 12th, 2008, 07:50 AM   #7
ujslost's Avatar
just tighten it with a wrench, you should be able to tell when its tight enough. dont torque the shit out of it. or your gonna strip either the bolt or the pan threads out. Then your gonna have to get a pan saver plug which suck balls
Old May 12th, 2008, 09:30 AM   #8
baine21225's Avatar
just replace the rubber piece
Old May 12th, 2008, 09:35 AM   #9
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
Order up an new bolt AND gasket.
Never fast enough.
Old May 12th, 2008, 01:03 PM   #10
can i just go to autozone/pep boys?
I'm a good boy now.
Old May 12th, 2008, 01:51 PM   #11
ryans88gt's Avatar
Well I'll tell you what I do. When I take the plug out for an oil change, I immediately wipe it off and put a little bit of ultra black RTV around the threads and base of the bolt.
I let it set up for about 20 minutes while I let the oil drain and change the filter. I wipe all the oil off the pan and then I put the bolt back in there just slightly tighter than hand tight. Let the RTV cure for a little bit while I put the car back on the ground, put tools away etc... Then I fill with oil, run it, and check the level. I have never had a pan bolt leak oil.
Old May 12th, 2008, 05:51 PM   #12
ujslost's Avatar
reckon how much of that rtv is unthreading off the bolt when you remove the bolt from the pan and getting in the engine?
Old May 12th, 2008, 06:53 PM   #13
JBIGBOOTSY's Avatar
1990 LX hatch
Wait....Your supposed to put the plug back in after you change your oil?
Old May 12th, 2008, 07:03 PM   #14
ujslost's Avatar
only if you want to. ya dont have to. its just one of those extra bolts ya throw away.
Old May 12th, 2008, 07:12 PM   #15
terribleonexx88's Avatar
terribleonexx88 is on a distinguished road
Send a message via AIM to terribleonexx88
my check oil sensor in the side of the pan leaks, how ironic
85 svo. work in progress
Old May 12th, 2008, 11:13 PM   #16
what is rtv?
I'm a good boy now.
Old May 12th, 2008, 11:19 PM   #17
ujslost's Avatar
automotive silicone glue. get the black if ya need some.
Threads Similar to: Leaking Oil
Oil leaking in car nasty92LX 5.0 Mustangs 3 August 12th, 2007 04:02 AM
Charger is on but oil is leaking nasty92LX 5.0 Mustangs 6 July 30th, 2007 01:56 PM
kickout 7qt oil pan w/low oil sensor hole Iownastang 5.0 Mustangs 2 July 19th, 2007 01:17 AM
possible leaking oil - ideas of normal causes RichM V6 Mustangs 6 April 26th, 2007 09:52 AM
Leaking Gear Oil? Stan27 General Tech 8 July 19th, 2006 11:38 PM
