Do stock foxbodys have 2 oil drain plugs?
Old May 12th, 2008, 02:35 AM   #1
1992 Lx
11.39@119.24
cuz mine does
Old May 12th, 2008, 02:38 AM   #2
e3sean's Avatar
1988 lx
9.68@142
e3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the rough
yes cause the sump in the front and back.
<font size=4><b>MILITARY CREW
Old May 12th, 2008, 02:39 AM   #3
1965 Mustang Fastback
nba1341 will become famous soon enough
how come?
I'm a good boy now.
[COLOR=red][B]slow car club - crew member 7 of 9
[COLOR=White]Mood: Cool :cool:
[/COLOR][/B] [/COLOR]
Old May 12th, 2008, 02:44 AM   #4
1992 Lx
11.39@119.24
you dont know what youre talking about noob
Old May 12th, 2008, 02:47 AM   #5
Justincredible's Avatar
Justincredible is on a distinguished road
They have a "forward" sump because the 5.0 and Windsor engines have the oil pump located at the forward half of the block, directly below the distributor. This forward sump is needed to clear the pump and happens to hold about 1/2 quart of oil.
The rear sump is the actual "oil reservoir" that holds the majority of the engines oil.
Obviously...both sumps are drained when changing the oil....if not...you will be mixing your new oil with the old/dirty oil that is held in the front sump.
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster .
BIVENS RACE CARS FTMFW!!!
Old May 12th, 2008, 02:48 AM   #6
why don't I have these 2 oil drain plugs....
I have a transmission plan plug to drain
an oil pan plug to unscrew in drain located at the back of the oil pan like a fire hydrant
I'm a good boy now.
Old May 12th, 2008, 02:49 AM   #7
1992 Lx
11.39@119.24
theres 2, both look the same, just one back further
Old May 12th, 2008, 02:50 AM   #8
1992 Lx
11.39@119.24
and thanks for explaining it justincrediblyhot
Old May 12th, 2008, 02:53 AM   #9
both located on the oil pan?
I'm a good boy now.
Old May 12th, 2008, 02:53 AM   #10
The pre-fox Mustang's engine is positioned higher over the K-member and did not have a "double sump". Thus...they have only one drain plug.
Pre Foxbody oil pan:
Old May 12th, 2008, 03:03 AM   #11
Here is a pic of a Fox body oil pan...if you look close, you can see the front sump drain plug.
Old May 12th, 2008, 03:08 AM   #12
thanks justin! I see now
I'm a good boy now.
Old May 12th, 2008, 07:55 AM   #13
1BADSTANG's Avatar
1BADSTANG is on a distinguished road
I can see clearly now, The rain is gone.
Old May 12th, 2008, 02:43 PM   #14
ryans88gt's Avatar
my 351w double sump pan only has a plug in the rear.
Threads Similar to: Do stock foxbodys have 2 oil drain plugs?
Fi W/stock Plugs hellbred07 2005 - 2010 25 February 4th, 2008 09:28 PM
One of the baddest foxbodys ive seen lately.. CAMN89GT Multimedia 1 November 16th, 2007 04:09 AM
Drain plugs RAMS#20 94-95 1 October 27th, 2007 10:36 PM
Supercharger oil drain klindz500 99-04 23 May 30th, 2007 11:39 PM
Oil drain screw size ? cobralini 5.0 Mustangs 3 August 24th, 2006 09:35 PM
