LinkBack (1) | Thread Tools |
#1
1989 LX Coupe
Clutch cable adjustments
I found the problem to my loose pedal and non-engaging clutch. The two nuts on the clutch fork side were loose as hell.
So, I tightened them and what do you know...the play in the pedal is gone. So...... I go to drive it and the clutch pedal comes almost all the way to the top before the clutch engages...it's undriveable like this. Do I just keep moving the tightening nuts back to get proper pedal feel and then tighten, or is the cable itself too far gone? I tried looking at the deal on the firewall, but it doesn't turn or anything so I don't know what to do with it. Halp!!
#2 | |
1987 ford mustang gt
well see when shes done
Just keep adjusting the cable until you pull the clutch about 2 inches off the floor where it should grab. I have to play with mine just so that it doesn't grind going into first.
Where the cable goes through the firewall, is it a threaded metal type fitting or just a large plastic fitting? if plastic I don't think it's a firewall adjuster. |
THe clutch cable should be adjusted so that the slack is just barely taken up. Then wherever the clutch releases is where it releases. Your clutch might just be severely worn.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/70859-clutch-cable-adjustments.html
| Clutch cable adjustments | This thread | Refback | May 13th, 2008 10:06 PM | |
Threads Similar to: Clutch cable adjustments
| Clutch Or Clutch Cable OR Shifter??? | 96GtGoodz | 96-98 | 21 | July 27th, 2009 02:59 AM |
| clutch cable? | 87merkur | 2.3 Mustangs | 5 | March 11th, 2008 11:01 PM |
| Clutch Cable | dStoltenberg | 5.0 Mustangs | 1 | June 19th, 2007 01:17 PM |
| CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS | Hububula | 5.0 Mustangs | 3 | May 28th, 2007 10:08 AM |
| Getting My Clutch Quadrant, Adjustable Clutch Cable and | 97Cobra | 4V / SVT | 3 | May 2nd, 2007 02:33 PM |
