Nothing but clicking when starting...
Ok..here is where I'm at so far:
Replaced starter last week and everything was fine until Friday night. Went to start car an get nothing but clicking. I have fully charged battery. Car starts when push started but not when jump started. Here is what I've done so far: Cleaned battery posts and installed new terminals replaced starter cable replaced negative ground cable from battery replaced starter relay on fenderwell made sure battery was good and even switched to another one Here's the weird part: When I swapped batteries, it started right up so I shut it off again and tried to restart and got nothing but clicking from relay again! I'm thinking(and hoping) that maybe it;s a lose connection somewhere. Any thoughts? BTW..this is my '88 5.0 5speed and not the car in the signature below
1982 GT (t-top) 351w(.060),10:3, ported & polished iron heads, 1.94/1.60 valves, BBK shorties & flowmasters, 274XE cam, stealth intake, mallory dizzy, stealth intake, 750dp, Edge 3700 stall converter, C-4, 4:10's Best E.T 12.79@103.55mph |
Did you replace the positive battery cable? Also check to make sure the positive cable to the starter is not grounding out on something, like the headers or motor mount (especially the headers, they will melt though the insulation in no time).
I had a similar problem and it was the positive battery cable (from battery to solenoid). It looked fine on the outside, but the inside was all corroded and not supplying enough current. Finally, could just be a bad reman starter.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
ive had a bad reman starter and it would do the same thing
BULLITT CREW #5 LT GTB mufflers for sale
1986 mustang gt convert
check to see if starter is tight bolted good..or it wont ground,,somtimes evn if it f eels like itrs bolted in its not...and yessomtimes a new one is bad too..have it checked at ya nearest parts store
Threads Similar to: Nothing but clicking when starting...
| clicking???? | orangerider32 | 94-95 | 3 | April 25th, 2008 10:22 AM |
| clicking | graystang01 | V6 Mustangs | 16 | January 7th, 2008 12:05 PM |
| Centerforce Clicking???? | SilverStang03 | 99-04 | 9 | October 17th, 2007 03:34 PM |
| clicking noise from engine when starting HELP!!! | victorye3 | V6 Mustangs | 7 | September 3rd, 2007 11:42 PM |
| What's the clicking..? | justinsstang | V6 Mustangs | 15 | February 10th, 2007 08:07 PM |
