Discussing Clutch Don't Work in the 5.0 Mustangs Forum. well i can change through gears when im stopped at a light but if i ...
Old October 28th, 2006, 03:06 PM   #1
Clutch Don't Work
well i can change through gears when im stopped at a light but if i try to shift from first to second and so on when im driving it doesnt work, but sometimes it does. i was thinking maybe the clutch cable needs to be adjusted but i dont know, can anyone plz help.
Old October 28th, 2006, 03:39 PM   #2
Asshole™
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Does the pedal feel sloppy? You might have a stretched cable or a bad factory clutch quadrant. Or the pressure plate could be bad too.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft
Old October 28th, 2006, 04:56 PM   #3
yeah i think it is the quadrant cause its really loose but is it supposed to be clicked in or out?
Old October 28th, 2006, 09:54 PM   #4
I don't know what year yours is but if it's a stock clutch and cable mid to late 80's, you can adjust it by pulling the clutch pedal towards you, then pushing the pedal to the floor. The quadrant if good will catch some adjusting teeth to make the adjustment . Not a great system but worked when I had my 86GT.
If you replace the clutch cable or clutch, don't make the same mistake I made by using the stock repalcement FRPP cable which has to be adjusted at the clutch fork, go for the fire wall adjusted unit, will save alot of hassle and crawling under your car to get the adjustment right. You will probably want to replace the quadrant too.
Threads Similar to: Clutch Don't Work
will this work or fit?? droppedbass87 96-98 5 August 4th, 2007 08:56 PM
CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS Hububula 5.0 Mustangs 3 May 28th, 2007 11:08 AM
Getting My Clutch Quadrant, Adjustable Clutch Cable and 97Cobra Drivetrain 3 May 2nd, 2007 03:33 PM
Clutch I need a clutch guru nHuman Engine 1 December 7th, 2006 09:11 PM
Stage 2 Clutch Kits Or Just Clutch Kits itschristorres8 V6 Mustangs 3 September 24th, 2006 10:15 PM
