Vacuum Pump
Old October 28th, 2006, 04:02 PM   #1
smbikes's Avatar
smbikes is on a distinguished road
Vacuum Pump
my car is building to high of a crank psi and it is leaking from aroung the in take bolts and any opening that it can find! I dont want to put a evach system on it becaus they are formore all out drag , dose any 1 know a car that came with a Vacuum pump that was not belt driven ??
302 ci bored 40 over converted to carb, comp cams XE274HR cam .555/.565 lift, much more , dyno'd at 471.8 HP @ 5700 RPM!!
Old November 1st, 2006, 12:06 AM   #2
smbikes's Avatar
bump..
Old November 1st, 2006, 08:48 AM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Ford was putting electric vacuum pumps on some cars but I don't know the specifics off hand. I just remember a couple local racers that were trying to aquire some from Ford to see how much vacuum they pull.
If you are building that much crank case pressure you need to figure out why. Putting a band aid on it will only make things worse.
Threads Similar to: Vacuum Pump
2007 Pump Gas Drags 32 of the fastest pump gas cars Mellon Videos 7 June 14th, 2008 12:08 PM
Where do I connect my vacuum pump? MonsterSD 5.0 Mustangs 1 August 12th, 2007 04:26 AM
vacuum... sivart 5.0 Mustangs 22 July 31st, 2007 11:02 PM
Mechanical pump, or existing in-tank pump? shnipplelicken 5.0 Mustangs 7 July 11th, 2007 11:47 PM
A1000 Pump With 255lph In-Tank Pump ? 92lx5oh 5.0 Mustangs 11 March 18th, 2007 08:51 PM
