Discussing bad egr - 1/4 mile in the 5.0 Mustangs Forum. how much time would i loose off a 1/4 mile for a bad egr. ...
Old May 14th, 2008, 03:39 AM   #1
Rustbelt's Avatar
bad egr - 1/4 mile
how much time would i loose off a 1/4 mile for a bad egr. there is no way that with my upgrades i should have a 16sec@87mph 1/4 mile. given i'm not hooking up well but i got slower by 2 sec. i should have shaved 2 sec ( ok not really but close)
upgrades: 65mm TB, explorer upper and lower, gt40p heads, "p" shorty headers.
Old May 14th, 2008, 03:44 AM   #2
1965 Mustang Fastback
yea that is really rally really slow for those mods what was your 60'?
Old May 14th, 2008, 08:35 AM   #3
Site Moderator
TurboLX's Avatar
1990 Mustang LX Turbo
8.67@165.91 mph
Whats the elevation of your track?
Wiring Diagrams, TSB's, OBD Service Codes and Engine Diagrams Available. PM For Info
Myspace
Old May 14th, 2008, 06:03 PM   #4
ujslost's Avatar
the egr should have no direct effect on your ET
1997 Mustang Gt Convertible for sale. Triple black, great condition and unmolested!
http://www.moddedmustangs.com/forums...like-most.html
Old May 14th, 2008, 07:51 PM   #5
fogged306's Avatar
89 GT
The computer disables your EGR during WOT anyway so the only thing a bad EGR hurts is MPG... which might be a wise investment with gas at 4 bucks.
Parts needed:
TKO 600
TwEECer, if anyone has one for cheap.
70mm TB
For sale:
Ford Racing E-303 cam, brand new
BBK 65mm TB, brand new
PM me if you want to buy/sell
Old May 14th, 2008, 11:24 PM   #6
Rustbelt's Avatar
I have no idea about the elevation... i think its around 350-400'. I didnt write down the 60' time it wasnt good but it wasnt that bad to have the 16 sec 1/4 mile. all my times are done via a vericom unit. i have access to an abandoned road .4 mile long and gated!
i thought that fogged, thanks.
there has to be a problem some where.
Old May 14th, 2008, 11:56 PM   #7
fogged306's Avatar
89 GT
I would go to a track and get a timeslip. Your 60' time is a good indicator of how much you're losing off the line. Check your basics too.. timing, if added timing what gas are you using, new plugs and wires, proper gap on the plugs, what tires and how do they look, what rear suspension are you using, ect.. The car might feel faster, but if you are losing enough grip off the line your time can be slower than before the mods.
Parts needed:
TKO 600
70mm TB
For sale:
Old May 15th, 2008, 01:33 PM   #8
87 mph is what scares me.. ur trap speed is a good indication of the potential of your car after you figure ur 60 ft and shifting into the equation.
94 Mustang GT 5.0
Cobra Hood, Front Bumper Cover,
wheels, 96 GT Tailights
Pypes Offroad X-pipe 2.5in
Flowmaster Super 40 Cat Back
High volume fuel pump
Pro 5.0 Short Shifter
ZEX 100 shot (dry)
13.6 @ 104.1mph 60ft @ 2.2sec. Street tires
Old May 15th, 2008, 02:41 PM   #9
ryans88gt's Avatar
If you EGR is stuck wide open that could be a problem, but I don't think it could be a 2 second problem, let alone a 4 second problem.
Timing? Distributor a tooth off?
89 LX 515 hp 497 ftlbs
88 GT 11.4 @ 118
Old May 16th, 2008, 04:06 AM   #10
Rustbelt's Avatar
going to check the timing this weekend. i still run 87 oct. i cant afford 93!!!! tires are new and good psi. next run i'll run them a little softer to try to hook better. the track is kinda far thats why the owner lets me use his property. shifting is no prob. its an auto. going to check the fluid level on that too. if the weather holds i'll run another 1/4 mile and get all the times. thanks
Old May 16th, 2008, 07:05 PM   #11
1993 5.ohhhh
14.47 at 96 mph
so you ran a 14 something before. But you expected to run low 12's with just heads?
99 towncar siezed motor
1996 v6 mustang 5 speed fed in the a by a bronco
1999 v6 auto drive way paper weight
1993 5.0 5 speed
http://i3.photobucket.com/albums/y51...thtrhtrhtr.jpg
Old May 16th, 2008, 09:41 PM   #12
ujslost's Avatar
I went from 14.0 or there abouts to a best of 12.95 with typhoon intake and dickflow heads
Old May 16th, 2008, 10:34 PM   #13
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
So you are saying you didn't run this at the track and get a timeslip? Don't bother comparing anything from a Gtech or any similar device. I haven't seen any that are anywhere near accurate. I bet that is your problem. Your combination should have no problem running high 13s on street tires.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow and Harold at Furo Racecraft
http://www.myspace.com/odarrellrules
Old May 17th, 2008, 05:30 AM   #14
Rustbelt's Avatar
hey darrell, i agree gtach and others are not accurate. the vericom unit is accurate. a drag strip would be best but not easy to get to. i agree i should be in the high 13's. i was running 14.9-15.2 before the heads and intake.
darrell the car is a SD car still, would a vaccum leak throw things off that much?
Old May 17th, 2008, 05:39 AM   #15
BWAL09's Avatar
2021 Mustang V12
Quad Turbo with nawz
Location: too busy giving handjobs to open my door for visitors
i don't know what the problem is, but keep doing whatever you're doing. i finally found a 5.0 that is slower than mine.
Originally Posted by Vinyl66 View Post
pointing out the fact that black people are indeed black isn't racist
slow car club - crew member 1 of 9
join www.moddedautos.com
Old May 17th, 2008, 09:02 AM   #16
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
I don't see how the Vericom is any more accurate than a Gtech. They opperate in similar ways. You won't know what the ET of the car is until you run it at a race track. Using a computer device on an abandoned road will get you close at best. Also if we assume the device you are using is 100% accurate, you will still not have near the same ET as you would at a race track because you are not on the same racing surface. Most race tracks have a concrete launch pad and use VHT, track bite or some other traction compound. My guess is you have a combination of an inaccurate device measuring your ET and MPH and a poor racing surface causing your high ET and low MPH.
A vacuum leak can make a big deal on any car. Did you hook the MAP sensor back up when you reinstalled the heads and intake?
Threads Similar to: bad egr - 1/4 mile
IAC BAD??? OR throttle body bad? Rico-mofos 99-04 10 March 12th, 2008 06:32 PM
Bad Wheelie Gone Bad... CAMN89GT The Clubhouse 7 November 16th, 2007 07:37 AM
Bad Bad Bad situation mustangmanic The Clubhouse 32 October 26th, 2007 10:55 PM
EGR triggerhappy101 5.0 Mustangs 2 June 8th, 2007 03:23 AM
bad bad wreck 232stang The Clubhouse 12 April 8th, 2007 12:37 PM
