Discussing craping out!! in the 5.0 Mustangs Forum. i have a all stock block heads intake 5.0 with vortech s trim 75mm ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
craping out!! |
I Touch Myself Sometimes
1991 GT
19.83 @ 12mph
plugs gapped correctly?
![]() MILITARY CREW FOUNDER SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX widebandsemail joe@tricktuners.com |
plugs are gapped around 30-33 i believe i'm thinking its something to do with tuning though....
What is your fuel pressure while under boost? 24# injectors with 14# boost seems like a combination that screams lack of fuel. I know you said the A/F is about 10 and starts to get a little higher, I wonder if it get a "little higher" really quick and flops.
1991 GT - Original owner, all stock 1988 GT - The project car |
1987 mustang lx 5.0
Are you using a laptop to tune it? If so then you might need to fool around with the air/fuel ratio chart or just set it back to the default settings
#6 | |
95 opalfrost gt
Whats the A/F when she starts spitting? 10.? at WOT seems a bit rich I would shoot for 11.8:1-12.0:1. Can you post a screen shot of your dattalog?
10:1 even on a wideband isn't a real number. It basically means it is too rich to be read accurately.
Are you using an FMU?
89 LX 515 hp 497 ftlbs 88 GT 11.4 @ 118
1990 LX hatch
Maf transfer function data, IMO
yes its definately needs leaned out a little bit in lower rpm WOT but around 5500 its starts to lean out to around 11, I dont have the data log software hooked up yet nor am i sure how it works
fuel pressure spikes to 100 when i get on the throttle and im pretty sure it stays up there through out the ranges i am using a FMU with a 8:1 disc i guess im just gonna haft to delete the FMU and go with 42's. I just dont see why it did'nt do it before i put the pms on |
the FMU isn't the problem and sounds like it is functioning normally.
you probably need to tune the FMU with a bleeder valve and/or different calibration discs (I have a whole set if you are interested, including a 7:1 and 6:1). Disconnect the PMS and see if you are still having the same problem. get that thing on a dyno so it can be tuned.
