Discussing gettin some head! in the 5.0 Mustangs Forum. I was wondering what kind of heads most of you guys prefer? I am finally ...
Old May 14th, 2008, 11:35 AM   #1
1991 Mustang Lx
gettin some head!
I was wondering what kind of heads most of you guys prefer? I am finally going to buy some. I was leaning to the afr 185cc because they look to be the biggest power adder, but also just about the most expensive. Just wanted some opinions.
Old May 14th, 2008, 11:58 AM   #2
ryans88gt's Avatar
for what?
89 LX 515 hp 497 ftlbs
88 GT 11.4 @ 118
Old May 14th, 2008, 01:56 PM   #3
93hatch's Avatar
1993 Lx
14.097/98.2
wont work on a stock block
Foxbodys FTMFW
yay no more centered threads!!!!!!!
Old May 14th, 2008, 03:36 PM   #4
e3sean's Avatar
you mean stock pistons...
well those are good heads but i would reccomend the trick flow twisted wedge heads just make sure they have brass valve guides
the only thing u will be burning by going with a 347 insted of a 331 is the guy driving the 331
MILITARY CREW
USAF LUKE AFB AZ,
E-4 AMMO I.Y.A.A.Y.A.S
Old May 14th, 2008, 04:46 PM   #5
JBIGBOOTSY's Avatar
1990 LX hatch
Old May 14th, 2008, 04:46 PM   #6
baine21225's Avatar
what is your setup and what are you plans with it.....
Old May 14th, 2008, 05:44 PM   #7
ujslost's Avatar
why wont the 185s work on a stock block?
1997 Mustang Gt Convertible for sale. Triple black, great condition and unmolested!
http://www.moddedmustangs.com/forums...like-most.html
Old May 14th, 2008, 11:00 PM   #8
jam77's Avatar
1987 Mustang GT
go with the tfs heads thats what i bought and they are awesome.
Old May 14th, 2008, 11:02 PM   #9
jam77's Avatar
1987 Mustang GT
they wont work with the stock pistons because they have 2inch valves and the pistons don't have releifs milled into them. The tfs heads do work because the intake valves are rotated.
Old May 14th, 2008, 11:23 PM   #10
ujslost's Avatar
never heard that before, i guess i learned something
Old May 15th, 2008, 12:03 AM   #11
Justincredible's Avatar
Yes....The TFS Twisted Wedge heads have a modified valve angle which allows for more piston-to-valve clearence per unit of valve lift. Aka you can have a 2.02 valve in the TFS TW head and use a stock piston up to about .520" of lift with ~225deg of duration @ .050 lift.
Old May 16th, 2008, 11:10 AM   #12
Smirnoff's Avatar
1982 5.0 t-top
could always go with the AFR 165'
Studies show that 92% of kids listen to rap. If you are one of the 8% who still listens to real music put this in your signature
Old May 16th, 2008, 11:19 AM   #13
ujslost's Avatar
i had a friend that ran afr 165s and consitantly ran 12.20s on motor, he had other mods too but that shows the 165s arent bad
Old May 16th, 2008, 01:52 PM   #14
91cobra5.0's Avatar
91 mustang
266 ftlbs 191 hp (15.138 @92.91)
i said it in a different post but.......
i dream of twisted wedges
Fender well cold air intake, 3:73's, MAC long tubes, O/R h pipe, eibach springs, 65mm TB, dual 10in electric fans, 3g upgrade, smog delete, advanced timing, MSD cap and rotor, ford racing 9mm plug wires, 75mm Pro-M MAF
Old May 16th, 2008, 02:36 PM   #15
stangage's Avatar
185 AFR all the way depending on what else you have done they will show....have some reliefs put into your pistons and youll be good
"That old Ford sure fast on the draw out run the Chevys and out run the law"
Old May 16th, 2008, 02:43 PM   #16
ujslost's Avatar
Old May 16th, 2008, 11:04 PM   #17
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
What is the rest of the combination?
Also, what the magazine articles say makes the most power is not always what makes the most power.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow and Harold at Furo Racecraft
http://www.myspace.com/odarrellrules
Old May 16th, 2008, 11:06 PM   #18
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
I've run the stage 2 TFS cam in alot of stock short blocks with Twisted Wedge heads and had alot of PTV left in it. I have not tried but I think you might be able to shoe horn the stage 3 cam in as well.
Old May 20th, 2008, 12:32 AM   #19
Onebadcobra's Avatar
93 Cobra Clone
12.8@106
AFR's all the way
Theres no replacement for displacement...but Im definately friends with Kenne and Mr. Whipple...
Threads Similar to: gettin some head!
my baby's gettin old DanTheMan 99-04 12 April 21st, 2008 09:49 AM
its gettin close prinzzz 2005+ 23 March 30th, 2008 10:53 PM
im gettin me WilltheThrill The Clubhouse 4 October 31st, 2007 02:54 PM
Gettin to be that time again. turp The Clubhouse 17 August 14th, 2006 02:46 PM
