Discussing 351W and a C6 into a Fox? in the 5.0 Mustangs Forum. My buddy and I are converting his 5.0 5spd inot a 351 W with ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#1 | |
1979 mustang 5.0
hopefully 11's when complete
the 351w will use the same motor mounts. the only different things he will need is an oil pan, headers. Also intake manifold, distributer and oil pump are different on a 351w....
as far as the C6 goes I've never heard of that being done..... Why would you? If you want a drag transmission build up a C4 and put a ratchet shifter in it. If you want a more streetable tranny use a tremec 5 or 6 speed.....
1979 hatchback: -351w w/ 10.5:1 -Tremec TKO |
1989 Mustang LX
10.98@126.7 NA
The C-6 is a little bigger physically than a C-4, you may run into some clearance issues, especially when it comes to headers. I don't know for certain about the drive shaft. I think the front yoke is the same but the length may be different. Any good drive shaft shop can fix that problem.
Never fast enough.
A 351 with a C6 will be slower than a 302 with a T5.
C6 is a junk tranny, don't bother with it. Sell it on ebay and buy a C4 or even an AOD.
89 LX 515 hp 497 ftlbs 88 GT 11.4 @ 118
#5 | |
Its his car, and he found this combo "deal" so I dno, I personally would have stuck with building the 5.0 block up, ill let him know that the tranny is garbage for his application though
1986 mustang gt convert
a c6 is good tranny,if built is stronger then most built c4s, but robs more hp then a c4,i think a shorty header is req when a c6 is used with its larger bell area..id get a c4 if ya wanta auto or get c6 built up along with good upgrades on the 351w,also if a 351w is mounted in a fox usually ya need a cowl hood for taller 351w..unless you use a drop engine mount like a solid kind or so..but 351w droped in place of a 302 is pretty simple drop in
1989 Mustang LX
10.98@126.7 NA
A stock C-6 is stronger than a stock C-4. The C-6 is heavier, larger and has an intigrated bellhousing. It will be a tight fit but it will go in. A sledge hammer helps with firewall and tunnel clearance. I would try to trade the C-6 off for a C-4 instead.
Never fast enough.
you cant run long tubes with a c6 like said above it will hit, it is a tight enough fit with a 302. i would loose the block get a 302 and put them heads on with a diff head bolt arp sells run a 5spd and it could be done cheap
"That old Ford sure fast on the draw out run the Chevys and out run the law" |
A C6 is heavy and sucks up about 100 hp. As far as strong, no not really any better than a C4.
1989 Mustang LX
10.98@126.7 NA
If that was the case, Ford would have just used the C-4 behind the 460 truck motor instead of the C-4
Never fast enough.
towing and drag racing are very different... *yawn*
and because ford did something, doesn't mean it is logical...for example the mustang II king cobra.
#12 | |
1989 Mustang LX
10.98@126.7 NA
Never fast enough.
#13 | |
#14 | |
1989 Mustang LX
10.98@126.7 NA
Never fast enough.
yeah, I guess that was a bad assumption on my part. With a 351w and C6, they are probably going to use the mustang as a tow rig.
1989 Mustang LX
10.98@126.7 NA
I can see how you could make that kind of mistake.
Never fast enough.
#17 | |
1990 Mustang LX
9.36@143 mph
I'd pull all of my finger nails and toe nails out with a pliers before I'd use a C6 in a performance application. Not only is it heavy and consumes a ton of power but it also will require tunnel modifications to get it to fit.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow and Harold at Furo Racecraft http://www.myspace.com/odarrellrules Videos of junk |
#18 | |
yes it is going to be a drag car, and i did convince him to get rid of the c6 for a c4, we still need heads, intake, and a drive shaft
Threads Similar to: 351W and a C6 into a Fox?
| 351w | djh1286 | Engine | 2 | February 25th, 2008 08:17 PM |
| 11 Second 351w | drthunder7 | 5.0 Mustangs | 21 | May 27th, 2007 11:06 AM |
| 351w | javier351lx | 5.0 Mustangs | 1 | May 14th, 2007 11:53 AM |
| 351w | javier351lx | Exhaust | 0 | May 13th, 2007 04:46 PM |
| 351W swap into a Fox body | Zeek | 5.0 Mustangs | 12 | November 4th, 2006 11:11 PM |
