347..speed density???
Old May 14th, 2008, 07:52 PM   #1
stangage's Avatar
stangage is on a distinguished road
ok just a few questions iam not to familiar with this stuff..I have an 87 with speed density iam putting a 347 in is it going to be a headache to put mass air in or should i just go carb.. it is going to have afr 185 with x303 cam what kind of chip and injectors would i need to run if i went maf ....THANKS
Old May 14th, 2008, 07:57 PM   #2
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
If I was in your shoes, I would leave the speed density and just run an AEM standalone. That way there is no need for a chip or MAF conversion. Thats just me, I dont know how you feel about self tuning, but that is what I would do.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old May 14th, 2008, 09:12 PM   #3
JBIGBOOTSY's Avatar
1990 LX hatch
The volumetric efficiency is diffrent so all the scalers and tables will be off.
Old May 14th, 2008, 09:22 PM   #4
Trans Am WS6
ThreeHonks302 is on a distinguished road
Send a message via AIM to ThreeHonks302
with your set up theres no way that the stock speed density system will work properly. Its fairly simple to do a MAF conversion and not too expensive either. It is possible to keep your car running on speed ensity but it must be tuned by a professional.I I were you I would just do the MAF conversion
Old May 14th, 2008, 10:03 PM   #5
ridebmxfbm's Avatar
1988 Mustang GT Vert
ridebmxfbm is on a distinguished road
dont get a cam just get a custom cam and you should be fine man... the only problem I see there is the cam... everything else looks good... so custom cam for SD should do it..
1988 GT Vert- 306 AOD built Trans, K&N Cold Air Intake, Mac Catback, many more mods... MAC Long Tubes Coming soon, Dr. Gas Custom X Pipe, 347 Stroker Kit Coming Soon...
Old May 14th, 2008, 11:05 PM   #6
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
???????? A cam thats going to work with s/d is prob going to be on the smaller side so vac isn't affected. Why bother if you spent the money on a 347 spend a little more and convert the thing to mass air it's not that hard to do.
Old May 15th, 2008, 05:53 AM   #7
stangage's Avatar
i know enough to know that SD will not take a big cam, and to have a 347 and afr 185 would be dumb not to have a cam that could support, i bought the computer and maf out of an 89, any suggestions on what injectors and what kind of chip i would need to get the most out of this set up....thanks for all your replies keep them comin
"That old Ford sure fast on the draw out run the Chevys and out run the law"
Old May 15th, 2008, 07:12 AM   #8
95opal's Avatar
95 opalfrost gt
An AEM doesnt care how efficient your motor is.
5.0 magazines
Old May 15th, 2008, 08:57 AM   #9
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
Carb that bitch. Seriously, less headaches and tuning is simple. Everytime you want to up the ante, you don't have to run off to get this or that changed, worry about whether you MAF is gonna like what ya did, match this to that, that kind of crap. On top of that, I will put a carbed engine up against an EFI at the track with the same engine / mods any day (and win). EFI street manners are alittle better but if you want a grandma car that plays nice on the street, buy a Taurus.
Never fast enough.
Old May 15th, 2008, 09:30 AM   #10
stangage's Avatar
I know carbs like the back of my hand...it would be alot easier..i think i might do that and save the efi for the next car....what kind of power do you think that setup will give me i would like to take it into the 10s
Old May 15th, 2008, 09:49 AM   #11
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
Need more specs.
Never fast enough.
Old May 15th, 2008, 10:26 AM   #12
stangage's Avatar
what do you all need...
Old May 18th, 2008, 12:13 AM   #13
HELLRAZR94's Avatar
1994 MUSTANG GT
HELLRAZR94 is on a distinguished road
i have a 94gt and im doing a 347stroke kit and x303cam to, and the only thing is im doing the edlebrook perf.rpm heades what kind of power are you thinking your going to get to the wheels
Old May 18th, 2008, 01:29 AM   #14
1987 ford mustang gt
well see when shes done
I thought you already ordered victor jr's?
And why are you going with an x cam?
its a 347 stroker kit not stroke kit.
Old May 18th, 2008, 09:48 AM   #15
stangage's Avatar
not sure if all is good high 300's i changed my mind on the cam iam gonna run comp xe cam did a little digging and with all of the newer heads the ford cams dont get me wrong i really like them but they are an outdated design..the comp cam will go good with my afr 185s, add some stickers and i should be in the 9's
Old May 19th, 2008, 01:11 AM   #16
HELLRAZR94's Avatar
1994 MUSTANG GT
was up iownstang why do you think your funny bitch your ride must be a real piece of shit if you dont even have a picture of it in your profile and if you such a smart guy why dont you come to modesto ca, so i can blow the doors of you piece of shit, fucking smart guy. did i spell that right bitch lol
Old May 19th, 2008, 01:36 AM   #17
e3sean's Avatar
1988 lx
9.68@142
i have a trickflow stage 2 in my 347 and i love it it is very streetable has good power and sounds great.
the maf conversion is easy i did it in my 88 with your set up get a set of 30lb injectors and a c&l with stock sensor and 30lb sampeling tube.
make sure up upgrade to a bigger fuel pump too.
<font size=4><b>MILITARY CREW
Threads Similar to: 347..speed density???
Supercharger on Speed Density? Red87DropTop General Tech 3 February 19th, 2008 04:48 PM
Cai for Speed Density Drick 5.0 Mustangs 16 September 19th, 2007 10:20 AM
Speed Density VS MAF Tr1gger 5.0 Mustangs 7 April 17th, 2007 10:24 PM
Speed Density or MAF? 8A_Honda 5.0 Mustangs 15 February 6th, 2007 08:04 PM
Speed Density Darrellx14 5.0 Mustangs 4 December 2nd, 2006 08:50 PM
