Discussing Shedding Weight in the 5.0 Mustangs Forum. Originally Posted by ujslost FIXT LOL... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#41 |
FREE DRAG RACER GAME, TRY IT!! http://www.StreetChallenge3D.com/sig...?referal=1BAD1 2007 mustang gt/cs 11.8 with legal stickys 1988 mustang gt gt40p combo, 125 wet shot. full bolt ons. 11's? |
#42 |
Yeah but did you jerk it to see if it absorbed any harmonics?
1991 GT - Original owner, all stock 1988 GT - The project car |
#43 |
they have a video up of it, try google.
#44 |
oh boy, this thread went downhill in a hurry...lol
Hey Jbig, whatdya doing this weekend? Sunday? Byron? Dragracing?
89 LX 515 hp 497 ftlbs 88 GT 11.4 @ 118
#45 |
1990 LX hatch
I am currently having some serious tuning problems. I put heads on, 30lb inj and a mass air tube for the inj. the car runs crazy lean(on the plugs), so I put the 24lb tube back in the maf with the 30lb injectors. Part throttle is fine, but full throttle cleans the plugs from dark to white in no time. I'm just gonna get a victor, and a quick fuel and call it a car.
#46 |
Are you sure you are lean?? It is really hard to read the plugs with unleaded gas and EFI. What does the grounding strap look like?
I would swear that I was pretty close when I put the procharger on based on reading the plugs, but actually I was richer than 10:1. Porcelain was just barely tan and no soot. Tuning my buddies car, we went up 5 jet sizes on the fuel (nitrous kit) and the plugs still looked white even though it was blowing black smoke. I finally quit trying to adjust A/F on unleaded gas with EFI. Too hard to read. What I did learn is that the porcelain is deceiving and the grounding strap sometimes gives a better read out. Wideband?
#47 |
carpet removal should be big
#48 | |
1990 Mustang LX
9.36@143 mph
stock K-member 58 lbs stock A -arms (each) 10.5 lbs stock spindle, strut, brake rotor and caliper (one side) 56 lbs stock 8.8 rear axle drum to drum 183 lbs stock front spring (each) 10 lbs stock rear spring (each) 9 lbs stock seat (LX - each) 36 lbs stock rear lower control arm (each) 7 lbs stock rear upper control arm (each) 3 lbs stock heater assembly 28 lbs sound dedner 22 lbs tar paper 23 lbs stock master cylinder 8 lbs stock battery 47 lbs stock driveshaft 19 lbs wiper motor and arms 6 lbs rear bumper support 31 lbs front bumper support 23 lbs center console arm rest/change compartment 8 lbs door crash braces (each) 18 lbs AJE chromoly K-member 16 lbs QA1 K-member 26 lbs AJE drop spindle (each) 9 lbs AJE tubular adjustable A-arm (each) 5 lbs AJE coil over strut and spring (each) 10 lbs 8.8 with Mark Williams 35 spline gun drilled axles, spool, yoke, Aerospace brakes, bracing, coil over brackets 182 lbs QA1 rear coil over shock and spring assembly (each) 8 lbs Aerospace front brake assembly (each) 14 lbs Mickey Thompson ET Front 26x4.5-15 (each) 12 lbs Mickey Thompson ET Drag 28x10.5-15 (each) 23 lbs Summit plastic drag bucket seats (each) 12 lbs Aerospace master cylinder kit 3 lbs Optima 8022-091 Battery 35 lbs Ford Racing aluminum driveshaft 14 lbs 17x9" AFS CobraR 95 chrome 24 lbs 17x10.5" AFS CobraR 95 chrome 26 lbs 17x9" AFS 03 Cobras chrome 27 lbs 17X10" AFS 03 Cobras chrome 29 lbs 17x9" AFS 03 Cobras satin 26.1 lbs 17x10.5" AFS 03 Cobras satin 26.5 lbs 18x9" AFS 03 Cobras satin 25.5 lbs 18x10.5" AFS 03 Cobras satin 29.1 lbs 17x9" BBS Spider 21 lbs 15x3.5" Bogart drag-on fly star 9 lbs 15x7.5" Bogart Classic Star 10.5 lbs 15x8" Bogart Classic Star 11 lbs 16x7" 91-93 Mustang Pony wheel 23 lbs 17x8" Bullitt satin 28 lbs 18x9" Bullitt chrome 29 lbs 17x9" Cobra R 25 lbs 17x8" Cobra 96 satin 23 lbs 17x8" Cobra 98 satin 21 lbs 17x8" Cobra 99 satin 22 lbs 17x8" Cobra 99 polished 25 lbs 18x9.5" Cobra R 00 chrome 29 lbs 18x9.5" Cobra R 00 powerder coated 27.5 lbs 17x9" Cobra 03 satin 25.5 lbs 17x9" Cobra 03 10th anniv 23 lbs 17x11" Fikse 16 lbs 18x9" FR500 satin 26 lbs 17x8" GT 99 satin 17 lbs 17x8" Mach I 03 satin 25 lbs 18x9" Mille Miglia MM11-2's 25 lbs 18x8" SSR Integral 19.5 lbs 18x9" SSR Integral 20 lbs 17x9" Steeda ultralights satin 21.5 lbs 17x9" Steeda ultralights chrome 24 lbs 18x9" Steeda ultralights satin 22 lbs 18x9" Steeda ultralights chrome 24.5 lbs 15x3.5" Weld draglites 10 lbs 15x8" Weld draglites 13 lbs 15x10" Weld draglites 14 lbs 15x8" Weld Rodlites 13 lbs 15x3.5" Weld pro-stars 10 lbs 15x8" Weld pro-stars 12 lbs 15x10" Weld pro-stars 14 lbs 15x4" Centerline Convo-Pro 9.5 lbs 15x8.5" Centerline Convo-Pro 12.5 lbs 15x4" Centerline Tel-Stars 12 lbs 15x8" Centerline Tel-Stars 16 lbs 15x7" 99 V6 Mustang wheels 14 lbs 17x9" Wheel Replica Bullitts 23 lbs 17x9" Wheel Replica Bullitts chrome 24 lbs 17x10.5" Wheel Replica Bullitts chrome 25 lbs 16x7" Crown Vic oem wheels 25 lbs 18x8.5" BBS RK (Silver) 19 lbs 18x10" BBS RK (Silver) 20 lbs 16x7" GT Waffle wheels 19 lbs 17x9" Konig Villain wheels 21.5 lbs
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow and Harold at Furo Racecraft http://www.myspace.com/odarrellrules Videos of junk |
#49 |
1990 Mustang LX
9.36@143 mph
5lbs to be exact......5lbs of rotating weight. The main thing is the strength due to the 1/2" diameter difference and the use of 1330 u-joints.
#50 |
ok check me out, cuz my stang is GUTTED!
no ac, no heat bullshit, heat exchanger, blower motor and all that crap behind the dash (duct work and all that climate control shit) rear seat delete, racing seats, no carpet, no sound insulation, no rear selt belts, no spare tire/jack no smog pump fiberglass hood, fiberglass hatch lexan glass take the interior paneling out and if u want to keep it just take the sound insulation out from under the panels and then put the panels back |
#51 |
another thing, u could get rid of the front bumper support shit underneath the bumper cover, and aluminum driveshaft i heard is real good too! the lil elbow box thing on the center console piece, the metal that mounts it to the floor is like 20 lbs its retardaly heavy
#52 |
1989 GT
KB 2.1L Flowzilla
^ what does your car weight?
Threads Similar to: Shedding Weight
| weight | JStang14 | 96-98 | 15 | March 19th, 2008 07:54 AM |
| Weight | Iownastang | 5.0 Mustangs | 60 | January 16th, 2008 04:18 PM |
| Power to Weight | theninja | Pictures | 8 | August 19th, 2007 12:47 PM |
| weight | slow98gt | 96-98 | 1 | March 11th, 2007 06:11 PM |
| weight | mustang1072 | V6 Mustangs | 32 | March 2nd, 2007 12:32 AM |
