Discussing Shedding Weight in the 5.0 Mustangs Forum. Originally Posted by ujslost FIXT LOL...
Old May 16th, 2008, 08:29 AM   #41
1BADSTANG's Avatar
Originally Posted by ujslost View Post
FIXT
LOL
FREE DRAG RACER GAME, TRY IT!!
http://www.StreetChallenge3D.com/sig...?referal=1BAD1
2007 mustang gt/cs
11.8 with legal stickys
sons 1988 mustang gt
Full bolt ons
mild build coming soon.
Old May 16th, 2008, 08:46 AM   #42
nolife's Avatar
Originally Posted by JBIGBOOTSY View Post
This is true, Ive held Ryans shaft in my hand too, it's defiantly a beefy one.
Yeah but did you jerk it to see if it absorbed any harmonics?
1991 GT - Original owner, all stock
1988 GT - The project car
Old May 16th, 2008, 08:48 AM   #43
1BADSTANG's Avatar
they have a video up of it, try google.
2007 mustang gt/cs
Full bolt ons
Old May 16th, 2008, 04:22 PM   #44
ryans88gt's Avatar
oh boy, this thread went downhill in a hurry...lol
Hey Jbig, whatdya doing this weekend? Sunday? Byron? Dragracing?
89 LX 515 hp 497 ftlbs
88 GT 11.4 @ 118
Old May 16th, 2008, 05:06 PM   #45
JBIGBOOTSY's Avatar
1990 LX hatch
I am currently having some serious tuning problems. I put heads on, 30lb inj and a mass air tube for the inj. the car runs crazy lean(on the plugs), so I put the 24lb tube back in the maf with the 30lb injectors. Part throttle is fine, but full throttle cleans the plugs from dark to white in no time. I'm just gonna get a victor, and a quick fuel and call it a car.
Old May 16th, 2008, 05:15 PM   #46
ryans88gt's Avatar
Are you sure you are lean?? It is really hard to read the plugs with unleaded gas and EFI. What does the grounding strap look like?
I would swear that I was pretty close when I put the procharger on based on reading the plugs, but actually I was richer than 10:1. Porcelain was just barely tan and no soot.
Tuning my buddies car, we went up 5 jet sizes on the fuel (nitrous kit) and the plugs still looked white even though it was blowing black smoke.
I finally quit trying to adjust A/F on unleaded gas with EFI. Too hard to read. What I did learn is that the porcelain is deceiving and the grounding strap sometimes gives a better read out.
Wideband?
88 GT 11.4 @ 118
Old May 16th, 2008, 06:10 PM   #47
rockybalboa's Avatar
carpet removal should be big
Old May 16th, 2008, 10:55 PM   #48
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by 1BADSTANG View Post
Other than tires, smog pump, and air conditioning, What are some good ways to shed weight in an 88 gt? I got rid of the rear seat seat belts, because i dont need them. No stereo, no smog pump.. Im looking around the car seems bare already lol what else can i do to lighten her up?
Here are some factory and aftermarket weights that I've personally weighed with calibrated scales.
stock K-member
58 lbs
stock A -arms (each)
10.5 lbs
stock spindle, strut, brake rotor and caliper (one side)
56 lbs
stock 8.8 rear axle drum to drum
183 lbs
stock front spring (each)
10 lbs
stock rear spring (each)
9 lbs
stock seat (LX - each)
36 lbs
stock rear lower control arm (each)
7 lbs
stock rear upper control arm (each)
3 lbs
stock heater assembly
28 lbs
sound dedner
22 lbs
tar paper
23 lbs
stock master cylinder
8 lbs
stock battery
47 lbs
stock driveshaft
19 lbs
wiper motor and arms
6 lbs
rear bumper support
31 lbs
front bumper support
23 lbs
center console arm rest/change compartment
8 lbs
door crash braces (each)
18 lbs
AJE chromoly K-member
16 lbs
QA1 K-member
26 lbs
AJE drop spindle (each)
9 lbs
AJE tubular adjustable A-arm (each)
5 lbs
AJE coil over strut and spring (each)
10 lbs
8.8 with Mark Williams 35 spline gun drilled axles, spool, yoke, Aerospace brakes, bracing, coil over brackets
182 lbs
QA1 rear coil over shock and spring assembly (each)
8 lbs
Aerospace front brake assembly (each)
14 lbs
Mickey Thompson ET Front 26x4.5-15 (each)
12 lbs
Mickey Thompson ET Drag 28x10.5-15 (each)
23 lbs
Summit plastic drag bucket seats (each)
12 lbs
Aerospace master cylinder kit
3 lbs
Optima 8022-091 Battery
35 lbs
Ford Racing aluminum driveshaft
14 lbs
17x9" AFS CobraR 95 chrome
24 lbs
17x10.5" AFS CobraR 95 chrome
26 lbs
17x9" AFS 03 Cobras chrome
27 lbs
17X10" AFS 03 Cobras chrome
29 lbs
17x9" AFS 03 Cobras satin
26.1 lbs
17x10.5" AFS 03 Cobras satin
26.5 lbs
18x9" AFS 03 Cobras satin
25.5 lbs
18x10.5" AFS 03 Cobras satin
29.1 lbs
17x9" BBS Spider
21 lbs
15x3.5" Bogart drag-on fly star
9 lbs
15x7.5" Bogart Classic Star
10.5 lbs
15x8" Bogart Classic Star
11 lbs
16x7" 91-93 Mustang Pony wheel
23 lbs
17x8" Bullitt satin
28 lbs
18x9" Bullitt chrome
29 lbs
17x9" Cobra R
25 lbs
17x8" Cobra 96 satin
23 lbs
17x8" Cobra 98 satin
21 lbs
17x8" Cobra 99 satin
22 lbs
17x8" Cobra 99 polished
25 lbs
18x9.5" Cobra R 00 chrome
29 lbs
18x9.5" Cobra R 00 powerder coated
27.5 lbs
17x9" Cobra 03 satin
25.5 lbs
17x9" Cobra 03 10th anniv
23 lbs
17x11" Fikse
16 lbs
18x9" FR500 satin
26 lbs
17x8" GT 99 satin
17 lbs
17x8" Mach I 03 satin
25 lbs
18x9" Mille Miglia MM11-2's
25 lbs
18x8" SSR Integral
19.5 lbs
18x9" SSR Integral
20 lbs
17x9" Steeda ultralights satin
21.5 lbs
17x9" Steeda ultralights chrome
24 lbs
18x9" Steeda ultralights satin
22 lbs
18x9" Steeda ultralights chrome
24.5 lbs
15x3.5" Weld draglites
10 lbs
15x8" Weld draglites
13 lbs
15x10" Weld draglites
14 lbs
15x8" Weld Rodlites
13 lbs
15x3.5" Weld pro-stars
10 lbs
15x8" Weld pro-stars
12 lbs
15x10" Weld pro-stars
14 lbs
15x4" Centerline Convo-Pro
9.5 lbs
15x8.5" Centerline Convo-Pro
12.5 lbs
15x4" Centerline Tel-Stars
12 lbs
15x8" Centerline Tel-Stars
16 lbs
15x7" 99 V6 Mustang wheels
14 lbs
17x9" Wheel Replica Bullitts
23 lbs
17x9" Wheel Replica Bullitts chrome
24 lbs
17x10.5" Wheel Replica Bullitts chrome
25 lbs
16x7" Crown Vic oem wheels
25 lbs
18x8.5" BBS RK (Silver)
19 lbs
18x10" BBS RK (Silver)
20 lbs
16x7" GT Waffle wheels
19 lbs
17x9" Konig Villain wheels
21.5 lbs
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow and Harold at Furo Racecraft
http://www.myspace.com/odarrellrules
Old May 16th, 2008, 10:59 PM   #49
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
I think the FMS aluminum driveshaft weighs almost the same amount as the stock driveshaft since it is larger diameter.
5lbs to be exact......5lbs of rotating weight. The main thing is the strength due to the 1/2" diameter difference and the use of 1330 u-joints.
Old May 24th, 2008, 09:50 PM   #50
ok check me out, cuz my stang is GUTTED!
no ac,
no heat bullshit, heat exchanger, blower motor and all that crap behind the dash (duct work and all that climate control shit)
rear seat delete, racing seats, no carpet, no sound insulation, no rear selt belts, no spare tire/jack
no smog pump
fiberglass hood, fiberglass hatch
lexan glass
take the interior paneling out and if u want to keep it just take the sound insulation out from under the panels and then put the panels back
Old May 24th, 2008, 09:58 PM   #51
another thing, u could get rid of the front bumper support shit underneath the bumper cover, and aluminum driveshaft i heard is real good too! the lil elbow box thing on the center console piece, the metal that mounts it to the floor is like 20 lbs its retardaly heavy
Old May 25th, 2008, 10:30 AM   #52
Arctic Fox's Avatar
1989 GT
KB 2.1L Flowzilla
^ what does your car weight?
Originally Posted by Juggalo_X View Post
I tried to set my hotmail password to penis once.... it said my password wasn't long enough
Threads Similar to: Shedding Weight
weight JStang14 96-98 15 March 19th, 2008 07:54 AM
Weight Iownastang 5.0 Mustangs 60 January 16th, 2008 04:18 PM
Power to Weight theninja Pictures 8 August 19th, 2007 12:47 PM
weight slow98gt 96-98 1 March 11th, 2007 06:11 PM
weight mustang1072 V6 Mustangs 32 March 2nd, 2007 12:32 AM
