Discussing Electrical Problem in the 5.0 Mustangs Forum. ok i was driving my car back from the race track and everything went dim ...
Old October 29th, 2006, 12:33 AM   #1
90Stang's Avatar
2005 Mustang
Electrical Problem
ok i was driving my car back from the race track and everything went dim and my volt gauge dipped to the red. i changed the battery, and alternator and still does not charge out of the red with the headlights and electric fan on. what else could be wrong in the electrical.
Old October 29th, 2006, 09:26 AM   #2
Check all the wiring good.
There is also a fusable link over by the Soleniod that might have burned up.
http://img.photobucket.com/albums/v6...ng8719/Sig.jpg
Eibach lowering springs,Intake ported to Max,Electric cooling fan,120Amp Alt.,FlowMasters,Jacobs FC1000 Ignition system with coil,King Cobra Clutch,APC Racing Seats
Old October 29th, 2006, 01:58 PM   #3
90Stang's Avatar
2005 Mustang
fusable link? where can i find it.
Old October 29th, 2006, 04:27 PM   #4
have the pulleys been changed on the car?
95 Mustang GT
Slow Bolt On Car
http://img61.imageshack.us/img61/8386/sig4rx2.jpg
www.steelcitystangs.com
Old October 29th, 2006, 05:36 PM   #5
stang fanatic's Avatar
most of them are hanging off the starter solenoid
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old October 29th, 2006, 07:57 PM   #6
I believe the wire with the fusible link is brown off the soleniod.
Old October 29th, 2006, 09:51 PM   #7
90Stang's Avatar
2005 Mustang
stock pulleys. could the soleniod itself cause any problems if it is bad because it has never been replaced.
Old October 29th, 2006, 11:05 PM   #8
I doubt it if it was bad the starter wouldn't work at all.
The last time my Alt. burned up it burnt the fusable link.
Look at the pic the Green wire is the replacement link kind of hard to see where it goes but you can see where it is.
Old October 30th, 2006, 12:57 AM   #9
On Probation
Tony_90fox's Avatar
hey man, my pullies have been changed but this problem just started and they have been on for a few weeks. I changed the battery but sometimes it still wants to die while at a stop light. Should i just bump my idle up a bit to around 800-1000 rpms? Or should i get a new alternator as well.
Old October 30th, 2006, 07:36 PM   #10
90Stang's Avatar
2005 Mustang
ok when my car is idleing it will charge pretty good, but as soon as i back out of the driveway the volt gauge starts bouncing around from red to normal and then the battery light and check engine lites will come on and the car will start to die then it will pick back up and drive a little further then do it again and again.
Old October 31st, 2006, 12:21 AM   #11
Check all ground wires and the wires to the Alt.
Old October 31st, 2006, 04:13 PM   #12
90Stang's Avatar
2005 Mustang
finally fixed it. thanks for everyones help. it ended up the battery was not properly grounded to the body.
Old November 2nd, 2006, 03:00 AM   #13
ha...ha.....ha......and just HOW many times have we found THAT to be the issue here?????
I think weve all been down that road or getting there...glad to hear ya got it!
Threads Similar to: Electrical Problem
Electrical problem..... Klawin Electronics 0 September 18th, 2007 10:24 PM
Big Electrical Problem scr110 Electronics 8 June 16th, 2007 11:26 AM
electrical problem Darren E 5.0 Mustangs 4 April 18th, 2007 05:00 PM
Electrical Problem terribleonexx88 5.0 Mustangs 12 November 6th, 2006 03:37 PM
Electrical problem -- 87 GT cobralini 5.0 Mustangs 6 July 23rd, 2006 01:27 AM
