Occaisonal Backfiring, Its More Like A Bog And Then Backfire
Old October 29th, 2006, 10:26 AM   #1
91GRNGT's Avatar
91GRNGT is on a distinguished road
Send a message via MSN to 91GRNGT Send a message via Yahoo to 91GRNGT
Hey there, i have a 91 gt, and i have been reading on this thing and I can't figure anything out, the problem is this.. Sometimes, maybe 1 time a week or 1 time every two weeks, it will bog a little and bump bump and then backfire a little, can anyone help please? Could this be my IAC or whatever dirty? I unplugged the IAC without any changes to the idle is this normal?? Please help.. If it were timing it would do it all the time wouldn't it??? The car runs very strong till this happens, but once I wait a min and then punch it she runs like hell. Please help...
1991 Mustang GT 306, with KB .30 over pistons, steeda #18 cam!
05 Dodge Neon "Daily driver" Does dodge and ford match???
Old October 29th, 2006, 10:29 AM   #2
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
I would think if you unhooked the IAC it would not run well...
SO if you unplug it and it runs the same I would think it would be the IAC...But I am not 100% positive on it beign the IAC though...
Facebook
Google+
Old October 29th, 2006, 10:44 AM   #3
91GRNGT's Avatar
anymore????? Opinions??? Thanks chris...
Old October 29th, 2006, 11:08 AM   #4
stang fanatic's Avatar
stang fanatic is on a distinguished road
you probaly wont see much of an idle change when you unplugged the iac unless you were loading up the engine and making it work. all the iac does is control your idle to maintain its set rpm when the engine is loaded up, like turning on the a/c, etc.
sound more like a mass air sensor issue
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old October 29th, 2006, 11:28 AM   #5
91GRNGT's Avatar
wonder if i can clean the MASS AIR??? Think contact cleaner will help??
Old October 29th, 2006, 12:13 PM   #6
Screemin3o2 is on a distinguished road
Send a message via AIM to Screemin3o2
well the IAC doesn't only control your idle when the car is under some sort of accessory load, it also allows airflow into your engine when the throttle plates are closed. you should see enough of a difference when you IAC is disconnected even when you are idling without a load.
95 Mustang GT
Slow Bolt On Car
www.steelcitystangs.com
Old October 29th, 2006, 12:56 PM   #7
91GRNGT's Avatar
i don 't see or hear any changes while the car is running..
Old October 29th, 2006, 03:28 PM   #8
I would definately try to clean the IAC and maybe replace the gasket. Carb cleaner will do it
95 Mustang GT
Slow Bolt On Car
Old October 29th, 2006, 03:51 PM   #9
91GRNGT's Avatar
ok i did check the iac, and it did go down in idle, and i pulled the mass sensor too, and it idled real shitty but never died then i plugged it back up and it started idling good again... I painted the engine up a little, I have to pressure wash it, and i figure when the paint gets cured up i would go from the top and clean all the old oil off and see what eles i got..
Old October 29th, 2006, 05:01 PM   #10
cali 5.0 is on a distinguished road
if u unplug the iac while the car is on then the car would cut off....
unless of course u were keeping it on.. i dont understand why u would suspect the iac being bad if the car backfires.. they have nothing to do with each other.. backfireing is usually the case of timing...
Old October 29th, 2006, 05:06 PM   #11
the backfiring shouldn't have anything to do with it but the bogging situation most definately could.
95 Mustang GT
Slow Bolt On Car
Old October 29th, 2006, 05:33 PM   #12
91GRNGT's Avatar
Umm cali, I have no ideal I am picking at straws here, that is why i posted this, don't u think if i knew what the problem was I wouldn't have posted?
Old October 29th, 2006, 06:07 PM   #13
no shit but it if it "backfires" every other week then i'd say tht thats not a problem at all so why even include tht..
about the bogging down if u have a friend with a 5.0 then jus swap iac motors and see if tht solves the problem and if it does thn u no tht u need a new iac...
Old October 29th, 2006, 06:25 PM   #14
91GRNGT's Avatar
any other opinions ????? Thanks for your input cali, I am intrested in other opinions still...
Old October 29th, 2006, 08:02 PM   #15
backfiring is a result of an unburned/or late fuel burn condition in which factors other than timing are involved...its at which time the backfire occurs that leads to which condition is existing
Old October 29th, 2006, 08:20 PM   #16
91GRNGT's Avatar
so where do u think i should check?? if it were doing it all the time i would think timing, this i don't think is the problem..
Old October 29th, 2006, 08:25 PM   #17
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Ignition timing, vacuum leaks, rocker arms too tight (if they are adjustable), bad head gasket.....that's what comes to mind so far.
Old October 29th, 2006, 08:29 PM   #18
is when idling, cruising, or throttling (definitely not during coast im sure)?
Old October 29th, 2006, 09:11 PM   #19
91GRNGT's Avatar
this only happens like when i go to drive normal sometimes after i drive it a bit sometimes not, this doesn't happen all the time., my egr valve doesn't have a vaccum line to it, also the engine was just built 2500 miles ago, that doesn't mean the headgasket isn't bad just letting ya know.. This happens like if i go out on the street and drive normal it happens, and when i get on it after letting off the gas she will run like hell, this only happens maybe once a week or two weeks, i have had the car for 1 month and it has only happend 2 times..
Old November 2nd, 2006, 02:03 AM   #20
Man, diagnosis like that are difficult since theres no frequency. clearly sounds like a sensor intermittently acting up, you may just have to wait for a failure to know which one.
Threads Similar to: Occaisonal Backfiring, Its More Like A Bog And Then Backfire
Intake Backfiring 90mustang 5.0 Mustangs 10 November 12th, 2007 10:17 PM
My Stang is backfiring! WombRaider 5.0 Mustangs 10 October 30th, 2007 09:15 PM
1995 mustang backfiring dsaleen2002 94-95 5 August 18th, 2007 10:38 AM
Backfiring 00vabchgt General Tech 6 June 19th, 2007 08:56 PM
Backfiring 00vabchgt 99-04 0 May 24th, 2007 04:26 PM
