Discussing Top Dead Center? in the 5.0 Mustangs Forum. Took off all my EFI componets so I am ready to get my motor switched ...
Old October 29th, 2006, 11:51 AM   #1
shockashark's Avatar
Top Dead Center?
Took off all my EFI componets so I am ready to get my motor switched to carb... One dum mistake so far is that I pulled my distributor without marking top dead center... Any notes on how to best do this on a 302 motor....???
Here is what the motor looks like so far after break down:
A quick note to anyone looking for spare parts for your Mustang EFI goto:
http://cgi.ebay.com/ebaymotors/ws/eB...2794138&rd=1,1
Old October 29th, 2006, 12:04 PM   #2
stang fanatic's Avatar
pull #1 spark plug, cut a piece of coathangar and stick it in the hole. remove valve cover, turn engine over, while watching the valves for #1. as the piston pushes the coathangar up AFTER the intake valve opens you will know you are on #1 compression stroke...then you can use your timing pointer and '0' should be top dead center (as long as the outer ring of the balancer hasnt slipped). If you find top dead center while the exhaust valve is closing, then you are at the exhaust stroke and one complete revolution of the crankshaft to tdc again will be compression stroke, where you can drop in your dist. again for #1
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old October 29th, 2006, 12:56 PM   #3
91saleentwinturbo's Avatar
he doesn't even half to take the valve cover off. he can watch the lifter in side the valley move up and down.
Old October 29th, 2006, 01:08 PM   #4
ok, right side valve is off if you are looking at the motor from the front of the stang
Old October 29th, 2006, 01:29 PM   #5
number 1 is on the other side and it's always the cylinder that sticks out the furthest.now just pull # 1 plug out and put your finger over the hole and have some one crank it over until you feel air pushing out your now on the compression stroke now use a rachet to get it where you want.I wouldn't stick a coat hanger in there
Old October 29th, 2006, 01:51 PM   #6
Thanks again for helping the new guy,
This is a little different from a DSM Motor... There be monster pistons on the hood.... Arrrr
Old October 29th, 2006, 05:40 PM   #7
I was trying to offer the single person route. my buddies tend to distract me more than help...
Old October 31st, 2006, 10:29 PM   #8
here is a easy way. take a 15/16 socket and manually turn the motor over until the timing marks line up with 0 on the pully. and then put your distributor in and make sure the rotor points in the 12 oclock position. that is the number 1 spark plug. once you get it in. if the car doesent start it is 180 degrees out all you have to do is turn the motor again until the 0 comes back around and put the distributor back in at the 12 oclock position and it should be good. sounds hard but very easy. i just did this past weekend on my 88 ho
Old November 1st, 2006, 09:53 AM   #9
Asshole™
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
That will work fine as long as number 1 is at the 12 o'clock position...
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft
Old November 1st, 2006, 12:52 PM   #10
ok, so far:
- harmonic balancer timing mark set to 0
- compression on piston one should be blowing out
- timing rotation at 12:00
- fire order 1-5-4-2-6-3-7-8
I went ahead and installed a Mech. Fuel pump so my project got a little deeper but the balancer came off easy and the cam cover was a little bear to work but its on so hear are some pics...
Old November 1st, 2006, 12:56 PM   #11
another shot.... The pic's are a little fuzzy will have to adjust my camera...
Old November 1st, 2006, 09:20 PM   #12
also number 1 doesn't have to be at 12 as you can put anywhere you want.so in other words if you got it at tdc and just dropped in the dis the post thats closest to the rotor can be number 1.
just a tip if you where in a hurry.
Threads Similar to: Top Dead Center?
My Center Console... ChrisJ Electronics 68 August 22nd, 2008 10:17 PM
99-00 Center Dash To 01+? energiesource Visual 11 December 21st, 2007 03:25 PM
center console wadepetersen V6 Mustangs 6 July 24th, 2007 09:20 AM
center console wadepetersen Visual 3 July 20th, 2007 08:57 PM
Center Caps Mustang Mike 99-04 2 July 8th, 2007 06:23 AM
