1990 mustang gt
eventually
heads
do you think the trick flow tw heads would be better than my stock heads on my 90 gt.. ive already got the tf upper and lower intake, 70mm accufab tb and egr spacer and a 76mm straight shot mac performance intake.. im also about to up the fi to 24lbs and get a fuel pressure reg and i havent made up my mind on the pump yet(190 or 255).. what do yall think?
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires |
1993 GT
13.2@105
I run the trick flow heads with trick flow intakes and cam and love it. I run 30lb injectors and i would have to say go with the 24lb'ers. I also have the 255 and would go bigger and if I were you go better and have room to grow instead of having to buy another pump or injectors if you keep doing mods.
89 GT
Yea much better. The stock e7 heads are the downfall of these motors. I wouldn't upgrade to the 24# injectors until you change the heads.
1990 mustang gt
eventually
what do you recommend w/ the tf heads?
89 GT
The 24's are perfect for the TW's, just don't install them when you still have the stock heads, it wont do you any good. Put them in at the same time you put the TW's in.
1990 mustang gt
eventually
do you think im under powered due to the larger intake?
89 GT
I couldn't tell you for sure there. You might be hurting yourself with that intake and stock heads, you might not. The difference will be minimal at best anyway. If Tmoss drops by he could answer that better than most.
#9 | |
#10 | |
1990 mustang gt
eventually
track
1990 mustang gt
eventually
so if i were to get the tw heads.. what else should i do to the motor?
aslo what kind of heads should i get Trick Flow Twisted Wedge Street Cylinder Heads for Small Block Ford - trickflow.com
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires Last edited by chickenbot; May 18th, 2008 at 04:31 PM. |
1990 mustang gt
eventually
http://www.trickflow.com/largeimage....t=TFS-5171B001
these look good for my app?
1990 mustang gt
eventually
Trick Flow High Port Street/Strip Cylinder Heads for Small Block Ford: TFS-5171B001 - trickflow.com
1987 ford mustang gt
well see when shes done
You dont need damn high ports for a mild 302 they require special headers and the valve cover rail is raised.
stick with the standard tw head Trick Flow Specialties TFS-51400004 - Trick Flow Twisted Wedge Street Cylinder Heads for Small Block Ford - summitracing.com bigger is not always better |
1990 mustang gt
eventually
do i need to do anything to the pistons with the heads and also what cam should i buy too
The heads will work fine with the stock pistons, i would probably call a cam grinder for a custom grind or go with the trick flow stage 1 cam.
1990 mustang gt
eventually
#18 | |
.499.510 |
1990 mustang gt
eventually
what kind of push rods and rockers would you recommend?
Threads Similar to: heads
| GT 40 X Heads. Need Help Deciding On These Heads, Or AFR`s | BillR1970 | Parts | 8 | May 12th, 2009 09:01 PM |
| 4V heads Vs 3V heads, and noob Q. | TheUNZippee! | 4V / SVT | 19 | February 5th, 2008 02:17 PM |
| GT40 heads vs GTP heads | 99TurboV6Stang | 5.0 Mustangs | 9 | September 18th, 2007 09:34 PM |
| RHS heads , are they good cylinder heads? | hitorx | 5.0 Mustangs | 25 | May 12th, 2007 09:55 PM |
| Boss 302 Heads Same As Cleveland Heads? | ken5_0 | Classic Mustangs | 8 | September 25th, 2006 03:18 PM |
