Discussing What Nitrous to run....... in the 5.0 Mustangs Forum. I have a 306 built block, trick flow h/i/c, full exhaust with long ...
Old May 16th, 2008, 12:27 AM   #1
1993 GT
13.2@105
I have a 306 built block, trick flow h/i/c, full exhaust with long tubes, 30lb injectors, 373's and some other stuff... and wanted to get a nitrous kit, i was wondering if anyone else has a simular setup and what they run. I want a good quality setup with everything i need included with different shot options. Any info is greatly appreciated. Probably over the inter I am going to look into getting a supercharger so I want something that will also work with that.
Old May 16th, 2008, 12:31 AM   #2
fogged306's Avatar
89 GT
The plate kit that sandwiches between your upper and lower is the best IMO. With those 30's you can probably get away with a decent shot of a dry kit. I'm not sure if they make the plate kits dry or not.
Parts needed:
TwEECer, if anyone has one for cheap.
70mm TB
Full length headers and matching h-pipe
For sale:
Ford Racing E-303 cam brand new
BBK 65mm TB, brand new
BBK equal length shortys brand new
BBK off road x-pipe for shortys used
Old May 16th, 2008, 12:32 AM   #3
1987 ford mustang gt
well see when shes done
plate kits are only wet or let me put it this way I have never in my life seen a dry plate kit.
Old May 16th, 2008, 12:33 AM   #4
fogged306's Avatar
89 GT
Thats what I thought. Wasn't 100% though.
Parts needed:
70mm TB
For sale:
Old May 16th, 2008, 12:39 AM   #5
1993 GT
13.2@105
what does a wet kit or a dry kit offers that the other one doesn't. Is one safer.
Old May 16th, 2008, 12:44 AM   #6
fogged306's Avatar
89 GT
You could say the wet kit is "safer" because it adds a metered amt of fuel while you spray, so there's almost no chance of going lean. A dry kit is just nitrous and relies on your injectors to keep the A/F at safe levels, but you can go lean if you don't adjust it properly.
Parts needed:
70mm TB
For sale:
Old May 16th, 2008, 12:47 AM   #7
1993 GT
13.2@105
SO what brand comes with everything I need to hook it up and do the wet and dry kits both come in the same shots.?
Old May 16th, 2008, 12:53 AM   #8
rk_2000_Z/28's Avatar
They make dry plate kits (Harris Speed Works :: EFI Nitrous Kits :: HSW EFI Wet & Dry Nitrous Plate Kits :: EFI Wet & Dry Nitrous Plate Kits :: HSW Sudden Impact EFI Dry Nitrous Plate Kit) but you will be somewhat limited by the 30#'s.
A plate or a single nozzle fogger will get you what you need. There is no difference in performance between the two. Both are easy to instal and remove once you are ready to add a S/C.
03 Cobra-475/441 to the wheels
02 SS-Sold
00 Z/28-Totaled
Official Black Terminator Club Member
Old May 16th, 2008, 12:53 AM   #9
fogged306's Avatar
89 GT
I have a NOS kit and it seems to be pretty good quality. You can get just about any hp size kit you can handle on a stock block. I would stay under a 200hp shot and probably closer to a 150 shot unless you add some end gap to your rings. If you go too big of a shot without more end gap, thermal expansion of your pistons can wreak some havok.. it's not always the case, but the risk is a lot higher.
Parts needed:
70mm TB
For sale:
Old May 16th, 2008, 12:57 AM   #10
NOS is a good brand. My tuner has installed and tuned dozens of kits of all shapes and sizes and the only brand he swears by is NX. He said they are the only kits that he has never had a problem with and their 'noids are guaranteed for life.
02 SS-Sold
00 Z/28-Totaled
Old May 16th, 2008, 01:02 AM   #11
1993 GT
13.2@105
Thanks for the input and since I don't have a stock bock I guess I don't have to much to worry about.
Old May 16th, 2008, 01:04 AM   #12
fogged306's Avatar
89 GT
No matter what the block, if you haven't file fit your rings for nitrous, you still run that risk.
Parts needed:
70mm TB
For sale:
Old May 16th, 2008, 10:53 AM   #13
Smirnoff's Avatar
1982 5.0 t-top
bottles are for babies...and pinks
Studies show that 92% of kids listen to rap. If you are one of the 8% who still listens to real music put this in your signature
Old May 16th, 2008, 11:30 AM   #14
ujslost's Avatar
1997 Mustang Gt Convertible for sale. Triple black, great condition and unmolested!
http://www.moddedmustangs.com/forums...like-most.html
Old May 16th, 2008, 02:59 PM   #15
ryans88gt's Avatar
lol...I used to think the same thing when I couldn't afford it...
If your not using nitrous, then your just getting beat by everyone that is.
89 LX 515 hp 497 ftlbs
88 GT 11.4 @ 118
Old May 16th, 2008, 03:06 PM   #16
Smirnoff's Avatar
1982 5.0 t-top
ha i just felt like being spiteful... but yes i do hear good things about NX
Old May 17th, 2008, 12:57 AM   #17
Editor
Goblin's Avatar
Secret In The Works
I just want to clarify here that, wet or dry, theres ALWAYS a possibility of going lean. Running a wet system does not in anyway, garuntee that you wont run into a lean condition because of hardware.
Always keep an eye on your plugs, and always make sure your hardware is in good working order before you spray. Its way better to be safe, than really sorry when it comes to this stuff. Anyone who uses Nitrous, knows what its like to feel stupid, and be sorry about mistakes they could have avoided.
Ive used a bunch of different Nitrous systems with EFI, and my personal prefference has always been NX. Understand though, no system or brand is the "best" by any means, but in my experiences with N20, NX makes good engineered systems.
Definition of Fast?
I'd say thats good enough.
NMRA Outlaw 10.5 Season Opener 2008
Photo courtesy of - Yours Truly
Old May 17th, 2008, 09:47 PM   #18
baine21225's Avatar
good stuff bro +1
Old May 17th, 2008, 10:41 PM   #19
ujslost's Avatar
I agree with baine. so I gotta go ahead and rep you on this.
Old May 18th, 2008, 09:16 AM   #20
JBIGBOOTSY's Avatar
1990 LX hatch
A wet kit will go lean only if fuel pressure drops. As bottle pressure drops, the system gets richer. A dry kit will force 1000psi of n2o to your FPR causing a spike in fuel pressure of up to 70-100psi. This forces more fuel thru your injectors. It is in no way metered. a 50hp dry kit gets as much fuel as a 125hp shot. That is why I stick to my guns when I say a wet kit is better.
Threads Similar to: What Nitrous to run.......
first nitrous run of my life! ricerraper33 Videos 18 April 27th, 2008 11:15 AM
Is it possible to run 11's with the GT with all boltons and some nitrous? SonicBlue281 99-04 13 February 28th, 2008 10:25 AM
Run,Vick, Run WAR-PARTY The Clubhouse 14 August 3rd, 2007 12:35 AM
Can I Run Nitrous Bone Stock? marcfiebka 99-04 8 July 16th, 2007 10:44 PM
Nitrous Dyno Run Haggis13 Poweradders 4 March 10th, 2007 02:03 AM
