Discussing help with control arms.... in the 5.0 Mustangs Forum. i bought lakewood upper and lower control arms and put them in last night... is ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
help with control arms.... |
i have southside upper and lowers with lakewood 50/50 shocks and mine is stiff as shit. Thats how it is.
i thought since u put the 50/50 in it would like drop down when you launch the car.isn't that what you want the back to drop down and the front to come up to hook better?????
did you tighten all the hardware before you loaded the suspension? if so jack it up and loosen everything again and let the car down and tighten again with weight of car on suspension
1997 Mustang Gt Convertible for sale. Triple black, great condition and unmolested!http://www.moddedmustangs.com/forums...like-most.html |
my car dead hooks. It might not fee like the bac will go down any but when your car leaves it will squat.
My dads car is the same way and he goes 7.80s on drag radials. With a 1.21 60ft. |
how am i supposed to tighten everything if i cn;t get under the car with the car being on the floor...
I Touch Myself Sometimes
1991 GT
19.83 @ 12mph
ramps...
![]() MILITARY CREW FOUNDER SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX widebandsemail joe@tricktuners.com |
if i have jackstands under the rear isn't tht the same as ramps the wieght of the car is on the suspension... i'll try watever works.
#9 | |
1990 Mustang LX
9.36@143 mph
Stock shocks are a 50/50 ratio. No you don't want the rear to squat. When a Mustang squats it is unloading the rear tires and wasting horsepower.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow and Harold at Furo Racecraft http://www.myspace.com/odarrellrules |
gotcha thnx alot darrell... i guess it should be ready to hit the track once i decide on which posi unit will hold up launches....
#11 | |
1990 Mustang LX
9.36@143 mph
Rebuild the stock rear end and call it a day. Or upgrade it using the Cobra carbon fiber clutch packs. Ryan did a detailed write up on rebuilding the stock traction lock. Trac-Lok rebuild how to.
#12 | |
#13 | |
1990 Mustang LX
9.36@143 mph
Maybe Ryan will chime in. I don't know a lot about the Cobra rear ends.
yes, you can use the 31 spline cobra diff. For drag racing, you're not putting nearly as much stress on the diff as you do taking corners under power.
My stock unit with 4 normal clutches is holding up to 500 hp at the wheels. The carbon fiber clutches are designed to hold upto 500 hp, so if you pack 4 of them, I would say you are more likely to break an axle than burn up the diff...maybe 750 hp. More than that and you might want to start thinking about a spool and 33s anyway.
89 LX 515 hp 497 ftlbs 88 GT 11.4 @ 118
1993 GT
13.2@105
Detroit True Track.....Hey Ryan how about you get your 750 ponies and test the theory of the clutches for us all....I just want to see your car have that power then I am buying a plane ticket to get a ride in your car...lol
91 mustang
266 ftlbs 191 hp (15.138 @92.91)
how much did the control arms cost you?
![]() Fender well cold air intake, 3:73's, MAC long tubes, O/R h pipe, eibach springs, 65mm TB, dual 10in electric fans, 3g upgrade, smog delete, advanced timing, MSD cap and rotor, ford racing 9mm plug wires |
It just a quick nitrous jet change away, but I like my engine in uno piece.
bought them for 200 of my friend he went a diffrent route.... ok so i should be fine with the 31 splines and the cobra rear i have a stock motor for now but im puting a turbo on it over the winter...
97 Cobra
your upper arms might be sticking...this is a known problem when changing these..if i was you i would put my stock uppers back on cause they dont bind...thats the only part of the susp ford did right...
Norcal SVTOA Sacramento Persident/Director
Threads Similar to: help with control arms....
| QA1 Tubular Control Arms (A-Arms) | keith0s | 5.0 Mustangs | 3 | October 19th, 2007 11:20 AM |
| steel control arms vs aluminum control arms | Saleenwolf720 | 99-04 | 1 | October 15th, 2007 01:32 PM |
| Upper Control Arms & Lower Control Arms | LUV2XLR8 | 2005+ | 6 | October 6th, 2007 11:45 AM |
| Steeda lower control arms (Trailing arms)? | kmjsmith | 2005+ | 6 | July 4th, 2007 04:59 PM |
| Control Arms | MnrlGry01gt | Suspension | 17 | August 16th, 2006 09:53 AM |
