Discussing harmonic balancer in the 5.0 Mustangs Forum. http://store.summitracing.com/partdetail.asp?autofilter=1∂=SUM%2DC4270&N=700+429 ...
Old May 16th, 2008, 11:47 PM   #1
chickenbot's Avatar
harmonic balancer
http://store.summitracing.com/partdetail.asp?autofilter=1∂=SUM%2DC4270&N=700+429 4839044+4294924929+4294908331+4294908282+429484012 6+4294871851+4294907673+4294871826+4294871848+115& autoview=sku
that is the hb that i bought and i put it on today and matched the key and imbalance as the one that i took off with the moveable counter weight.. well it also came with this sleeve that idk where it goes and it still vibrates like crazy.. but the old one was horrible so it needed to be replace.. im gonna try to go tomorrow and move the counter weight around.. also when i moved the weight it only had 1 screw hole that i could match up to instead of the 2 that it needed.. and when i was bolting the pulley back on it i had to get longer screws due to the size diff.. but i had to cut 2 screws in half to make them fit b/c of the counter weight.. any ideas?
1990 gt 5.0
Mac Performance 76mm straight shot intake
70mm Accufab tb and egr spacer
Trick Flow Track Heat u/l intake
3.55 gears
MSD distributor, Blaster Coil, and 8.5mm wires
Old May 17th, 2008, 02:56 PM   #2
chickenbot's Avatar
does anyone know anything about harmonic balancers
1990 gt 5.0
3.55 gears
Old May 17th, 2008, 03:13 PM   #3
chickenbot's Avatar
do i need a 50 or 28 oz
1990 gt 5.0
3.55 gears
Old May 17th, 2008, 05:35 PM   #4
nolife's Avatar
Not the one you bought
I read the instructions that Summit provides with that model. Looks straight forward. Did you heat the HB in boiling water or the oven first? My guess is maybe the HB did not seat fully on the crank, that may have been why some of your bolts did not seem to work. According to the directions, you should not touch the weights, with the weights in place, it should be for 50oz.
1991 GT - Original owner, all stock
1988 GT - The project car
Threads Similar to: harmonic balancer
Harmonic Balancer shurb125 5.0 Mustangs 14 December 3rd, 2007 01:01 PM
89 5.0L harmonic balancer Rutcutter Want to Buy 0 June 9th, 2007 10:33 PM
Harmonic Balancer shawn91stang 5.0 Mustangs 4 January 6th, 2007 12:24 AM
Harmonic Balancer cobraetti 5.0 Mustangs 2 December 3rd, 2006 09:23 AM
Harmonic Balancer shockashark 5.0 Mustangs 5 November 12th, 2006 10:19 PM
