Cam Choice
Old October 29th, 2006, 07:05 PM   #1
ninedee-coupe is on a distinguished road
Cam Choice
i was planning on putting a cam into my stock motor just for this summer. now i was told with certain cams you need to shave your piston head in order to gain valve clearence so i wanted to know what type cam b/e/f/x/z can i use without needing any clearence...?
Old October 29th, 2006, 07:12 PM   #2
come on guys im planning on buying a cam soon i need to know
Old October 29th, 2006, 07:24 PM   #3
MSO
MSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the rough
Send a message via AIM to MSO
hav patience u cant jus wait 7 mins and expect an answer
do some research, i kno it sux but its the best way
only ask when ur completely stumped
if ur lazy ur gonna get a lazy answer...... like this one
[SIGPIC][/SIGPIC]
Old October 29th, 2006, 07:27 PM   #4
lmao wow thanks a lot buddy.. im sure darell will come along and solve this...
Old October 29th, 2006, 07:32 PM   #5
MSO
it doesnt matta anyways
ur only here to get this little piece of info and when u get it we'll never see u again
so
nah j/k
[SIGPIC][/SIGPIC]
Old October 29th, 2006, 07:33 PM   #6
wow your a lil weird eh? plz dont msg on this topic ne more
Old October 29th, 2006, 07:35 PM   #7
MSO
im sorry i wont do it again
[SIGPIC][/SIGPIC]
Old October 29th, 2006, 07:36 PM   #8
MSO
i promise
[SIGPIC][/SIGPIC]
Old October 29th, 2006, 07:36 PM   #9
MSO
no for real, i won't
[SIGPIC][/SIGPIC]
Old October 29th, 2006, 07:45 PM   #10
5-0stank is on a distinguished road
wow...probably one of the gayest comments ever
sorry to call u out but come on...darrell is one of the smartest guys on here, but everyone has something to offer
oh yeah, and mystangopens, ur funny! hahaha
1995 GT::Sold!
Looking for another stang...
Old October 29th, 2006, 07:46 PM   #11
k wel can you help me?
Old October 29th, 2006, 07:51 PM   #12
yes...first off, there are tons of threads about cams on here. i currently am running the ford b-cam. it is not that great of a cam, and many people would recommend a trickflow stage 1 or similar by comp or crane cams. if u want a streetable cam the stage 1 is a good choice. since your engine is stock that would be an ok choice. if you want a ford cam, i would get the e-cam (more lift but less duration than the b cam)
dont expect tremendous gains from just a cam. other things such as heads, intake, fuel supply will boost power alot with a cam
1995 GT::Sold!
Old October 29th, 2006, 07:54 PM   #13
stang fanatic's Avatar
stang fanatic is on a distinguished road
darrell can speak for experience and should know...but in all reality, any one will tell you it doesnt matter what cam you buy (except for stock), you always, and i mean always, check valve to piston clearance unless your are famously riich and dont care
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old October 29th, 2006, 07:57 PM   #14
haha yes, or pray for the best
1995 GT::Sold!
Old October 29th, 2006, 08:25 PM   #15
Jojogunne's Avatar
1984 GT
13.21@104.61
Jojogunne is on a distinguished road
If someone told you , you need to shave your pistons, Don't get any more advice from them.
You will get too much lift pushing the valve so it will smack the top of the piston. Not good. Any reputable dealer should be able to help you with this. Good luck in your research.
I am running a Comp cam. ( part #31-218-2 ) I nice little boost but not to radical for the street.
I got heavier valve springs, so my original rockers wouldn't fit so I need to get roller rockers. Now my nice aluminum valve cover wouldn't fit. Be prepared. We all have an expensive hobby.,
jjg
Eibach Sportsline, Mac, Moroso,Comp Cams,PRW roller rockers, and no money left over.
Old October 29th, 2006, 08:32 PM   #16
Piston notching, or cutting notches deeper is a common practice for typically high lift cams and dome pistons, so its not stupid advice, probaly a little more like premature to unwarranted for your situation
Old October 29th, 2006, 08:33 PM   #17
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Is that a smart ass comment? I'm not exactly sure where you're going with that......
As for your original question, you said "putting a cam into my stock motor just for this summer". Are you saying you are going to put a cam in for this summer and then put the stock cam back in???? If so, why? Don't bother wasting the time. Otherwise, if I misinterpreted what you said then a good cam for a stock engine if you really feel you need one is a Trick Flow part number TFS-51402000. It should spice things up a bit and give a noticeable idle tone but don't expect big gains because with a stock engine you won't have big gains with a cam change. You will most likely need to change your valve springs as well. You can probably get away with the stock springs but when you damage your valvetrain (or worse) don't say I didn't tell you. In all honesty I wouldn't waste the time, money or energy on putting a cam in a stock engine. Guys are running 11s with stock cams. The gain on a stock engine isn't worth it, but that is just my opinion.
Old October 30th, 2006, 12:07 AM   #18
anyway, you want to put a cam around all of the stuff on your engine. a cam should be one of the last things you do. Like somebody said, the stock cam is capable of holding its place until things get pretty modified. Save that money and start saving some more for heads and intake, then get the cam and you'll love it.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old October 30th, 2006, 03:40 AM   #19
vipereater86 is on a distinguished road
Send a message via Yahoo to vipereater86
i have to agree with darrell. but i do have a z303 cam in my stang and it lopes like a son of a bitch and i love but i did have to get the pistons notched for clearance.
Old October 30th, 2006, 08:23 AM   #20
Jojogunne's Avatar
1984 GT
13.21@104.61
Sounds like you should rebuild everything. If you get new heads with out doing anything to the bottom end. The top (heads ) are nice and tight while the bottom is ...... lets call it well worn you will end up changing the bottom sooner then later, Unless you plan on just cruising with this car ; and that is fine too.
jjg
Threads Similar to: Cam Choice
Take your choice TurboLX The Clubhouse 16 August 13th, 2007 09:53 PM
a choice Modern_Muscle 2005 - 2010 7 June 9th, 2007 05:16 PM
cam choice phat94 94-95 3 April 11th, 2007 07:48 AM
Cam choice Nice 5.0 5.0 Mustangs 5 January 12th, 2007 05:26 PM
cam choice... 2ToneFox 5.0 Mustangs 4 August 13th, 2006 01:46 PM
