need help asap!!!!!!!
Old May 17th, 2008, 02:57 PM   #1
88stangGT is on a distinguished road
my horn doesn;t work anymore... i checked fuse there good.. when i hit the button i hear the relay clicking but no horn. what could cause this and how to fix. cn;t drive car until its fixed!!!!!!!! thnx alot guys
Old May 17th, 2008, 02:59 PM   #2
chickenbot's Avatar
1990 mustang gt
eventually
chickenbot can only hope to improve
does the horn start your engine or are you an obsessive horn blower
1990 gt 5.0
Mac Performance 76mm straight shot intake
70mm Accufab tb and egr spacer
Trick Flow Track Heat u/l intake
3.55 gears
MSD distributor, Blaster Coil, and 8.5mm wires
Old May 17th, 2008, 03:19 PM   #3
no just need a horn i live in the city and theres always people jumping out and trying to cut you off..
Old May 17th, 2008, 03:23 PM   #4
chickenbot's Avatar
1990 mustang gt
eventually
does your lighter or your cruise control(if you have) work?
1990 gt 5.0
3.55 gears
Old May 17th, 2008, 03:28 PM   #5
nasty92LX's Avatar
nasty92LX is on a distinguished road
i have the same prob with my horn it just makes a clicking noise. I think it might be the clock spring or a relay.
Old May 17th, 2008, 04:08 PM   #6
yes lighter and cruise control both work.... the relay makes a clicking noise is it supposed too????
Old May 17th, 2008, 04:10 PM   #7
2008 Hammock Rodeo Champ
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
Squints has a spectacular aura aboutSquints has a spectacular aura about
Send a message via AIM to Squints
check the horn itself. i had one where the wire worked itself loose and viola, no horn.
i have no mustang. so don't listen to anything i say.
Old May 17th, 2008, 06:07 PM   #8
Bigfatts's Avatar
Badass Mother 3000
Twice as fast as your ass!
Bigfatts is on a distinguished road
Check the ground on the horn. I had the same problem with my Capri. The horn just quit working. I ended up replacing it only to have the new one not work. I shined up the spot where the ground connected to the frame and it worked like a charm.
Old May 17th, 2008, 06:57 PM   #9
the horn i kno works i connect directly to battery and it went off... what ground are you talking about? is it somewhere i can see it from under the car or on top... i still think the relay is fuked up. im gettin one monday..
Old May 17th, 2008, 07:18 PM   #10
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
The metal bracket on the horn is the ground
Never fast enough.
Old May 17th, 2008, 09:07 PM   #11
then why when i hooked it up to a battery the metal bracket wasn;t touching anything and it still beeped?
Old May 17th, 2008, 11:29 PM   #12
Bigfatts's Avatar
Badass Mother 3000
Yes on some the bracket is the ground, on others there is a wire. If they aren't grounded properly (touching bare metal) the horn won't work properly.
Old May 17th, 2008, 11:40 PM   #13
ok the horn works fine.... i don;t hear the relay clicking..... and i checked the wires behind the steering wheel and they looked burnt...... the fuse is good..... what should i do....
Old May 18th, 2008, 04:12 AM   #14
82GT is an unknown quantity at this point
I used to have the opposite problem in my '88GT. The horn would suddenly go off and sometimes in the middle of the night!
My problem was the contacts so I just got another center piece(center of steering wheel) and the problem was solved. I suggest you just go get another piece from the junkyard for $5 and call it a day.
1982 GT (t-top)
351w(.060),10:3, ported & polished iron heads, 1.94/1.60 valves, BBK shorties & flowmasters, 274XE cam, stealth intake, mallory dizzy, stealth intake, 750dp, Edge 3700 stall converter, C-4, 4:10's
Best E.T 12.79@103.55mph
Old May 18th, 2008, 11:17 AM   #15
neverfastenough1's Avatar
Ok, your relay clicks in the first post, but now doesn't click. sounds like you have a short somewhere between your relay and the horn that now overheated the wiring in the column causing you to no longer get the clicking relay. If you have a test light, chase down the spot that you lose power. Check to make sure there is no power at the horn. More than likely not since the relay no longer clicks.
Old May 18th, 2008, 11:52 AM   #16
the horn i pulled out of the car. im gettin a new relay tomorrow. then i guess i will start over again and see if i can figure this problem out
Old May 18th, 2008, 12:07 PM   #17
fogged306's Avatar
89 GT
If the wires look burnt up there, then you have to take the wheel off and see whats going on. The cheap fix would be to catch the horn wire before the relay and install your own momentary pushbutton in the dash somewhere... assuming the relay works after you install the new one. If there are wires burnt though, you'll want to check for a short like neverfastenough1 said berfore you do anything.
Old May 18th, 2008, 03:01 PM   #18
1982 Mustang GT, SVT Swap
galzamar is on a distinguished road
since the horn works and the fuse is not blowing the problem is from the switch, winding in the steering wheel, or the wire to the horn, you need to use a volt ohm meeter and test to see if you have 12 volts at the horn when the button is pressed. if not work you way back, test the switch at the steering wheel if you get no voltage there it is either the switch, winding, or wire to the fuse panel. just have to do pin points tests and test each component if all the component are good then do a ohm test on the wire to make sure you have continuity and not a broken wire.
Old May 19th, 2008, 05:40 PM   #19
ok i put the new relay in and its still not clicking.. im gonig to taking apart the wires in the sterring wheel and hopefully find something in there if not im lost ....
Old May 19th, 2008, 08:58 PM   #20
did you just check the fuse or did you actually check to see if there is voltage at the fuse?
Threads Similar to: need help asap!!!!!!!
need help asap 91cobra5.0 5.0 Mustangs 8 April 16th, 2008 07:20 PM
Help Asap! Till 5.0 Mustangs 21 February 8th, 2008 03:16 PM
help asap please WeCircleTheProblem V6 Mustangs 14 August 16th, 2007 06:21 PM
NEED HELP ASAP!! 92stang0802 2.3 Mustangs 53 July 5th, 2007 12:03 PM
NEED HELP ASAP!! VetteC5RFrEak 5.0 Mustangs 0 August 3rd, 2006 02:01 AM
