Power valve keeps going bad...why?
Old May 17th, 2008, 06:19 PM   #1
82GT is an unknown quantity at this point
The car is running pig rich at idle and has fouled all the plugs. The last few times it has done this, the PV was blown and without taking the carb bowl off, I'm pretty sure it's blown again.
What makes a PV rupture? I know backfires can cause them to rupture but the car has set all winter with only an occasional start up now and then.
It seems like every year I have to replace it.
The car hasn't been driven on the roads since last summer and now the PV is probably bad again?....it doesn't make sense!
How can a car go from running perfect to running super rich just from setting in a garage for the winter?
1982 GT (t-top)
351w(.060),10:3, ported & polished iron heads, 1.94/1.60 valves, BBK shorties & flowmasters, 274XE cam, stealth intake, mallory dizzy, stealth intake, 750dp, Edge 3700 stall converter, C-4, 4:10's
Best E.T 12.79@103.55mph
Old May 17th, 2008, 11:13 PM   #2
JBIGBOOTSY's Avatar
1990 LX hatch
Dirty carb circuts. They will cause a whole range of problems.
Old May 18th, 2008, 10:56 AM   #3
tmoss's Avatar
tmoss is on a distinguished road
if it was backfiring hard eonough to blow the valve, I'd think you'd know it. Also, depoending on the year carb, it may have the ball-check in the passage to keep from blowing the valve.
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
Old May 18th, 2008, 11:16 PM   #4
ujslost's Avatar
if its an old carb with out the powervalve blowoff, i would but the blow off kit
Old May 18th, 2008, 11:24 PM   #5
1989 lx convertable
11.30
punkid is on a distinguished road
if it sat all winter the ethonol in the gas now a day eats at the rubber makeing it soft this might be why it goes bad so often
Old May 19th, 2008, 03:17 PM   #6
ryans88gt's Avatar
maybe time for some dissasembly and cleaning if you let it sit all winter without at least adding some fuel stabilizer.
Threads Similar to: Power valve keeps going bad...why?
Power Steering Valve Kenn Classic Mustangs 1 May 5th, 2008 02:34 PM
IAC BAD??? OR throttle body bad? Rico-mofos 99-04 10 March 12th, 2008 06:32 PM
Egr Valve And Pcv Valve Delete? Jeffery9508 V6 Mustangs 16 January 28th, 2008 09:45 PM
Bad ass super charged power wheels! man_of_war2081 Videos 18 November 4th, 2007 05:46 PM
bad idle and no low range power AtlanticBlue99 General Tech 49 February 17th, 2006 03:57 PM
