Dead ICM?
Old May 19th, 2008, 04:34 PM   #1
Hunt_chevs's Avatar
2002 Gt
Not Slow
Dead ICM?
car was running fine, just advanced timing to 14/15*,and it was running excellent massive more throttle response... i parked at a friends turned off and everything after a normal drive. when i go to start back up and leave, no spark. motor turns and turns,. just never fires. I replaced the ignition coil stupidly thinkin it would be a qwik fix and nothing. so now i got a nice red msd blaster chillin not even workin. So im thinking it could either be a bad ignition control module,.. or the stock 6al box dilly. Any help would be greatly appreciated. i got a full tank of 100 octane that needs to be ripped through.. sooner the better
Old May 19th, 2008, 04:40 PM   #2
ryans88gt's Avatar
Do you have a MSD 6AL box? If you ground and unground the white wire to going to a 6 AL that should force it to spark. If nothing, then it is the box or wiring going to the box.
Old May 19th, 2008, 04:46 PM   #3
Hunt_chevs's Avatar
2002 Gt
Not Slow
no, no 6al, only the msd blaster. But i was thinking that it could be the stock box that was faulty, or the icm.. like i said the motor turns and turns, just never kicks over... frustrating none the less
Old May 19th, 2008, 11:25 PM   #4
Hunt_chevs's Avatar
2002 Gt
Not Slow
up 4 some help
Threads Similar to: Dead ICM?
MM is dead!!!!!!!! MSO The Clubhouse 17 September 14th, 2007 08:14 AM
MM is dead.. again MSO The Clubhouse 34 August 25th, 2007 10:34 AM
MM dead? MSO The Clubhouse 130 August 13th, 2007 01:02 PM
Is he dead? turp The Clubhouse 43 June 28th, 2007 07:53 AM
dead t-5 5litercobra 5.0 Mustangs 2 November 26th, 2006 11:56 PM
