2008 Hammock Rodeo Champ
clutch & flywheel ?'s
i'm not sure what kind of power my car is making. but assuming that the engine is in good shape, i'd think it would be kinda strong (i don't have unreal expectations for it though.) considering what it has on it. edelbrock heads (don't know which though) lunati cam (again, don't know which) cobra intake, bbk fenderwell cai, full MAC system; shorties, o/r h, 2 1/2" catback(waiting to be installed). under drive pulleys, 70mm TB, and a few other little thing that aren't really performance mods.
then there's an aluminum d/s, bbk short throw, and 3.73's anyway, to get to my questions. i'm going to be putting this POS in the shop very soon, and was wondering if these variables should effect my decision on which clutch and flywheel to get. also, should i even worry about ordering things for my car, or just let the shop get it for me? i know i can find good deals on the internet. but, will shops generally charge more for installation of parts not sold by them? i just like doing it my way, cause i don't have to drop such a chunk at once. i can get stuff piece by piece and then go in for the labor once i have everything. anyway, any advice on clutch and flywheel choices would be appreciated. p.s. to make a long post even longer, any HP estimates based on the mods that i have? just an after thought. thanks guys. ![]() -Brandon
i have no mustang. so don't listen to anything i say. |
1993 GT
13.2@105
you would have to be more specific on what parts you have for the pony power as for the clutch, I have herd many good things about spec and use one myself and like it alot........unless you plan on putting down a lot more power in the near future I would just get the stock flywheel resurfaced if able to. Talk to the guys at your shop and see what they say about you getting the parts...
98 Cobra
your making for than me
did you mean more than you?
![]() and i was looking at your sig and it reminded me that i forgot to mention mine has the smog and a/c deleted as well. i don't know how much hp that gives you, but....
93 Cobra Clone
12.8@106
Ive had king cobra, centerforce, and spec clutches in a few of my stangs and i like the pedel the most on the centerforces...dual friction clutches are real nice..ive always used fidenza aluminum flywheels
Theres no replacement for displacement...but Im definately friends with Kenne and Mr. Whipple... |
I'd be looking into a Lakewood bellhousing at the same time. I've had a clutch explode doing a burnout on the street. I won't own a 5 speed car without a steel bellhousing anymore. I'll have to dig up some pictures...
Shit! Exploded a clutch on the street? I've done 3 gear clutch burnouts, but haven't had one come apart yet. A good bell housing is a good investment.
The ford HD (non king cobra), the one you need steroids to push the pedal...that is my favorite clutch. It has held up to nitrous launches at 5000 rpms without missing a beat for years without destroying the transmission and is still very drivable (besides the huge pedal effort). M-7563-A302N pressure plate and M-7550-A302N disc or M-7550-X302 disc. I have a king cobra in my other car and it doesn't have the same holding power, but the pedal is very easy. The spec stage 2 is also a nice clutch, stage 3 is way too grabby for the street though. centerforce is OK, but overrated in my opinion. Only seem to have about the same holding power at the king cobra. Ram also makes a decent clutch.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
These are the only pictures I could find without digging deep. You can see the clutch is no longer there. Some of it was stuck in the floor and the rest was in the fire wall. It destroyed the starter, bellhousing and block. It completely sheared off every bolt holding the bellhousing to the engine and put a hole in the block in the number 8 cylinder. Even the headers were beat to shit from debris flying around. When a clutch explodes, it is very bad news. They usually take a leg or two off your body. That was luckily not the case this time.
what causes a clutch to do this?
and, people have really lost legs from this? damn.
usually high rpm launches, but sometimes they just fly apart. You know there is always that 1 in 10,000 part that gets through quality control that should have never left the factory.
hope i never see this. i know it would never be this bad in my stang, but this is freaking nuts.
It happens alot more than 1 in 10,000.
I was just saying that there is 1 in 10,000 that flys apart for no reason. The rest fly apart due to extreme use and abuse. I haven't had one go yet...not looking forward to it...that looked like a mess. Isn't there a kevlar bag you can wrap around the bellhousing to make SFI approved? I know they make scatter shields like that.
1993 GT
13.2@105
When I bought my car it had a fresh 6 puck spec put in it and at first with the locker it was impossible to drive and park in reverse, but with my new rear it is a lot better and streetable.
#15 | |
#16 | |
LOL, yeah a 6 puck is not made for street driving. It is an ON/OFF switch.
Interesting, I had never read that before and have one in my 91 Mustang. That explains a lot. That clutch and my 2.73 leads to excessive pain in traffic.
Threads Similar to: clutch & flywheel ?'s
| Clutch / Flywheel | sgrcltpunk | 99-04 | 17 | April 1st, 2008 01:27 PM |
| New Clutch w/ Flywheel ??? | Montanasvt | 4V / SVT | 8 | January 25th, 2008 01:12 AM |
| need brakes and new clutch/flywheel | 07stanggt | 2005 - 2010 | 4 | December 27th, 2007 04:51 AM |
| New Clutch/Flywheel And Now Its Worse?! | obdnanr | V6 Mustangs | 20 | November 28th, 2007 07:30 AM |
| ? about Centerforce clutch and flywheel | WilltheThrill | 99-04 | 4 | February 20th, 2007 04:07 PM |
