LinkBack (1) | Thread Tools |
#1
98 Cobra
fan shroud
did ne one put thier shroud back on when they converted to electric fan? does it help any?
i know that with the stock fan cooling is decreased without it, since the air movement from the fan is not centered on the radiator... but im not sure if its differnet with an electric fan... dont most electric fans come with their own shroud anyways?
98 Cobra
kind of a mini shroud
you should be fine then. Are you having any problems with lack of cooling so far?
98 Cobra
nope but its starting to get hot outside so i waqnt to keep it cool as possible
you should be fine then... there is a small shroud on you fan too, i can see it a lil in ur sig. BTW, did u notice any difference from the stock fan to electric?
98 Cobra
wieght, and yea it does seem to rev a bit easier a little bit more throttle response. i think it was worth the 30$ i spent on it
oh wow thats pretty cheap... i think ima gonna have to do that same thing real soon. looks better too than that big stock shroud, but i got mine painted to make it look purty lol
98 Cobra
me 2 mines blue
the fans were out of a taurus?
98 Cobra
no some newer foreign car
2002 Gt
Not Slow
![]() iTrader: 1 reviews
1983 mustang lx
^i used some heavier zip ties to attach my electric fan to my radiator
98 Cobra
+1
i barrowed my friends dremel and used a permanent marker and just eyed were i thought needed to be cut and just cut way at the little mini shroud that is around the fans then i did the zip tie thing and it holds firm so....
93 Cobra Clone
12.8@106
I put in an electric fan without the shroud....works great
Theres no replacement for displacement...but Im definately friends with Kenne and Mr. Whipple... |
im gonna have to go electri very soon then, i've only been hearing good things... the only thing that has been holding me back is the wiring. How difficult is it and what must be done to wire the right way?
98 Cobra
you have to wire in a relay but that is really simple.
No shroud with an electric fan. Every electric fan I've seen has a shroud built in.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/71815-fan-shroud.html
| fan shroud | This thread | Refback | May 19th, 2008 11:32 PM | |
Threads Similar to: fan shroud
| Taurus fan vs Mark vlll fan | black88 | 5.0 Mustangs | 1 | September 20th, 2007 07:57 PM |
| C&L CAI Installation - Filter Shroud - Question | MSCLCAR | 2005 - 2010 | 21 | August 7th, 2007 10:51 PM |
| Fan Shroud - Four Core Radiator for '66 289 | Grvy65 | Classic Mustangs | 4 | April 22nd, 2007 11:23 PM |
| electric fan vs fan clutch | hmotes | 5.0 Mustangs | 8 | December 19th, 2006 02:03 AM |
| Electric fan or Flex fan? | vivoronte | 5.0 Mustangs | 20 | February 10th, 2006 10:58 PM |
