Two Questions...
Old May 19th, 2008, 11:31 PM   #1
1985 Mustang GT
matt0114 is on a distinguished road
Two Questions...
1. I went to the dyno last weekend. I put down 210 hp / 248 tq. Should i really expect anymore than that from the mods i have listed in my garage link (in the sig)
2. Lately when driving at night the headlights cut out randomly. Just the headlights though, not the dash lights or instrument panel lights. What should i check first? (one note, if i keep the high beam lever pulled all the way back all the time the lights do not cut out)
Thanks in advance,
Matt
Old May 19th, 2008, 11:35 PM   #2
2008 Hammock Rodeo Champ
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
Squints has a spectacular aura aboutSquints has a spectacular aura about
Send a message via AIM to Squints
Thanks in advance,
Matt
1. probably. if you're getting say 15% loss, that's like 247 at the ole crank. 20% loss would be over 260 hp. i don't know how much loss is to be expected though.
2. my '86 does the exact same thing. i'm thinking it has to be the switch on the column.
i have no mustang. so don't listen to anything i say.
Old May 19th, 2008, 11:40 PM   #3
1983 mustang lx
83fox is on a distinguished road
the dyno sounds about right
youll start seeing bigger gains in power with aftermarket heads and a custom grind cam, and depending on your c/r and the miles on your motor, a 347 stroker kit since its already a 306
Old May 19th, 2008, 11:42 PM   #4
1987 ford mustang gt
well see when shes done
Thats really good for e5 heads
Old May 20th, 2008, 12:00 AM   #5
1985 Mustang GT
and now to threadjack my own thread
what will it take to get around 300ish to the wheels?
1.set of heads (will sending my heads to get worked - port/polish/bigger valves- be good enough, or will i notice a bigger difference from buying some TFS heads?)
2.custom grind cam (estimate on cost please)
3.??????
4.??????
Threads Similar to: Two Questions...
TV questions 06RedfireGT The Clubhouse 8 February 14th, 2008 01:15 PM
h.i.d questions 03StangGT 99-04 10 December 31st, 2007 05:56 PM
5.0 HP Questions ! Smoph 5.0 Mustangs 4 April 15th, 2007 01:40 PM
Two Questions Clayhistorian V6 Mustangs 15 April 10th, 2007 10:11 PM
New! few questions Brian66D Modular Mustangs 19 March 22nd, 2007 11:00 PM
