1989 Mustang GT 5.0L
clutch problem!
I just bought a 1989 mustang 5.0L from my neighbor so I am new to the mustang world! It runs great but I do have a question though:
The clutch pedal is very stiff and I have to push it to floor as far as it will go to actually shift to any gear. Shifting to first and reverse causes the gears to grind and it doesnt just slide in, I have to shove it into gear. When I'm driving and shifting from any other gear, shifting is not smooth at all, I really have to use some muscle to push the shifter into gear and at the same time if I dont have the clutch pedal forcefully to the floor the gears just grind. My neighbor did say that the clutch was aftermarket but is this normal? Either way the car is more of a hassle to drive because gears do not shift smoothly and the pedal is so hard to push down. What do I need to replace or adjust to fix this? |
adjustable clutch cable or a new ford cable with a firewall adjuster
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
![]() welcome to the forums.
sweet, I guess Ill purchase a new clutch cable, whats the difference between an adjustable clutch cable or the cable with a firewall adjuster? And where would the best place to buy either of these online?
On the reverse grinding issue. Just put it into 5th then into reverse. that is how i do it and no grinding. I think they all grind going into reverse. It is the T5 transmission. They are like that.
Like I said first put into 5th then into reverse. Works for me
1989 mustang GT 5.0
1992 Lx
11.39@119.24
no syncro for 5th gear
#7 | |
1992 Lx
11.39@119.24
adjustable cable, which is what i have, adjusts under the car, you just tighten or loosen a nut on the cable, firewall one you can adjust from under the hood, so you dont have to climb under the car. i think mine was like 40 bucks off summmit
94 GT
ebay is also a awsome place
94 GT - Deep Forest Green Off road X, flowmaster single chambers, typhoon intake, hurst short throw, CAI, eibach sportlines, 315s, foxbody short block ![]() |
Threads Similar to: clutch problem!
| clutch problem? | blue03mach1 | 99-04 | 30 | January 18th, 2008 06:04 PM |
| Clutch Problem? HELP | EasyE64 | V6 Mustangs | 40 | November 27th, 2007 09:45 PM |
| clutch problem | rob madison | 96-98 | 5 | October 26th, 2007 11:06 AM |
| problem with clutch. | mike96gt | 96-98 | 2 | September 21st, 2007 04:33 PM |
| clutch problem | rottikk | 5.0 Mustangs | 6 | November 28th, 2006 10:03 PM |
