Fan Shroud Necassary??
Old May 20th, 2008, 07:33 PM   #1
built351w's Avatar
1979 mustang 5.0
hopefully 11's when complete
built351w is on a distinguished road
Question
Well I'm assembling my car together now and for those of you who don't know I have a 351w that will push about 400hp and planning on a 150 shot down the road. I bought a summit direct fit aluminum radiator that is like 2 3/4 in deep. I also bought an electric fan that has no plastic shroud around it, it's just an open metal fan that bolts to the radiator and it pulls 2100cfms.
So my question is this, Do I need a radiator shroud, or will I be plenty cool without one???
1979 hatchback:
-351w w/ 10.5:1
-Tremec TKO
Old May 20th, 2008, 07:38 PM   #2
91cobra5.0's Avatar
98 Cobra
id use one, do you still have the sotck fan shroud?
Old May 20th, 2008, 07:41 PM   #3
Trans Am WS6
ThreeHonks302 is on a distinguished road
Send a message via AIM to ThreeHonks302
yea you should use one, it will center the airflow on the radiator
Old May 20th, 2008, 08:57 PM   #4
2008 Hammock Rodeo Champ
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
Squints has a spectacular aura aboutSquints has a spectacular aura about
Send a message via AIM to Squints
mmm hmm. same concept as a fan boat. without the shroud they would hardly move. or, at least wouldn't move as fast. but with it, all the air is concentrated in one direction.
i have no mustang. so don't listen to anything i say.
Old May 20th, 2008, 09:11 PM   #5
built351w's Avatar
1979 mustang 5.0
alright, I'll have to get one.... thanks guys!!!
1979 hatchback:
-351w w/ 10.5:1
-Tremec TKO
Old May 20th, 2008, 09:58 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
What brand of fan is it?
Old May 21st, 2008, 03:34 AM   #7
teal89's Avatar
89 Mustang Lx
teal89 is on a distinguished road
I don't care what anyone else says but I would run with the shroud because metl fan or plastic, enough rpms on the fan and you can kiss your finger, hand, arm, neck.... body parts goodbye.
It will be plenty cool without one, but plenty unsafe without one too, you never know you might forget just how close the fan is spinning and might chop a finger so be safe and use the shroud.
94-95 306, B-Cam, Off-brand BBK Like Headers, H-Pipe, 3.73's, Nitrous Wet Shot 175 Shot
Old May 21st, 2008, 09:40 PM   #8
1983 mustang lx
83fox is on a distinguished road
my fan has a plastic cage that fits tight around the fan all the way around to the radiator. unless you let kids poke their fingers in the engine bay with the fan goin, its safe not to use the shroud
Old May 21st, 2008, 09:58 PM   #9
03gt
klfutrelle is on a distinguished road
I would run a shroud because it helps direct airflow(and will keep the engine cooler vs. without using a shroud) and it will also keep you from getting your fingers, hair, etc. caught in the fan if you're working on the car.
Old May 22nd, 2008, 12:17 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Most electric fans have a build in shroud or blade design that is optimum for performance. Adding a shroud to it can hurt airflow and causing cooling issues.
Old May 22nd, 2008, 12:21 PM   #11
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
my friends dad was working on a truck without a fan shroud and the fan flew off it didnt hurt him...it killed him
Old May 22nd, 2008, 01:20 PM   #12
teal89's Avatar
89 Mustang Lx
^ Like I said my friend... use a shroud. and it's not safe without one eithier. If that one kid had a brain, he'd know kids poking around with the car on and the shroud not on there is unsafe so use a shroud, hey it's your finger man.
Old May 22nd, 2008, 01:22 PM   #13
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
good to know.
thanks
Old May 22nd, 2008, 01:31 PM   #14
Holy Dick Castle!
dr.gonzo!'s Avatar
I was working on my car and hit the back of my fingernail on the blade. good god damn that felt good
Old May 22nd, 2008, 01:34 PM   #15
ryans88gt's Avatar
Buy an electric fan that has its own shroud. Using the stock shroud with an electric fan will not work very well as darrell pointed out. In order for the stock shroud to work the fan blades have to be at the edge (actually, just outside) of the shroud, otherwise it just impedes the flow.
Old May 22nd, 2008, 04:59 PM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Sorry about your friends dad. Unfortunately a wimping plastic shroud would have not saved his life. Fan shrouds are designed for cooling, not to retain a fan that takes flight.
Old May 22nd, 2008, 05:01 PM   #17
Holy Dick Castle!
dr.gonzo!'s Avatar
true...but it could have deflected it enough to miss him. It could go either way, final destination anyone?
btw it was like a late 70's big block chevy on swampers that he was working on. I dont know if those trucks even came with shrouds.
Old May 22nd, 2008, 09:15 PM   #18
1983 mustang lx
thats a very unfortunate thing to happen. but at the rate that fan was spinning at, a plastic shroud would barley deflect the fan. when it comes to spinning metal and stationary thin plastic, spinning metal usually wins
Old May 23rd, 2008, 02:27 AM   #19
teal89's Avatar
89 Mustang Lx
Do any of you know if that's a proven fact or is that all based on brain science? Fan Shrouds is not only used JUST for cooling. It's also to aid in the safety for individuals and to help minimize hazards to those near. My parents malibu has electric fans and above it, there's a shroud like thing around that that sticks out further than the fans.
Old May 23rd, 2008, 12:12 PM   #20
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yes, it is a fact if you use a shroud not designed for that particular fan you can do more harm than good. It has been tested over and over again since the day shrouds were invented. Most electric fans have a shroud already and are optimized for airflow. Adding another shroud can actually restrict the airflow. These companies spend alot of R&D on their products.
Threads Similar to: Fan Shroud Necassary??
fan shroud 91cobra5.0 5.0 Mustangs 17 May 20th, 2008 11:42 AM
Taurus fan vs Mark vlll fan black88 5.0 Mustangs 1 September 20th, 2007 07:57 PM
C&L CAI Installation - Filter Shroud - Question MSCLCAR 2005 - 2010 21 August 7th, 2007 10:51 PM
Fan Shroud - Four Core Radiator for '66 289 Grvy65 Classic Mustangs 4 April 22nd, 2007 11:23 PM
Electric fan or Flex fan? vivoronte 5.0 Mustangs 20 February 10th, 2006 10:58 PM
