Where'd it go?
My car (1990 LX 5.0, pretty much stock) has been making this weird knocking sound when I'm driving. The last time it did that it needed coolant. I put coolant in it this time - a full bottle. The radiator was full for a second, but after a couple of minutes, the coolant level was low again. I put a second, full bottle, of coolant in and it did the same thing, and is now overheating when I drive. Where is the coolant going? Does this mean I have a crack in my block somewhere? Busted Thermostat? Any help would be appreciated!!
run the car and watch for a leak and youll have your problem
98 Cobra
check your hoses
is your car smoking? white smoke, or smell horrible?
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences 02' GT ~ Twin Screwed 469hp/493tq |
1990 LX hatch
You may have never fully filled you car up in the first place.
Fill with the car running, top off, wait for the thermostat to open, then top off. |
1993 5.ohhhh
12.97 @140mph
I couldn't imagine you couldn't see were such a large amount of coolant was going to. My car does drain out that overflow tank pretty dam nfast, and doesn't ever get to normal temps when running. Hell Id lick my intake manifold after racing 6 times.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
#7 | |
1989 GT
KB 2.1L Flowzilla
+1 There could still be air trapped in your cooling system. |
Where'd it go?It does start smoking after about 20-30 mins of driving, and it has a rust smell to it (if that makes sense). But after letting it cool down and opening the radiator, the coolant level is low again! ![]() Thanks everyone for the feedback! |
1990 mustang gt
check the oil to see if milky if so you have a head gasket problem or even a head let loose
2002 Gt
Not Slow
![]() iTrader: 1 reviews
Thanks Hunt chevs & JBIGBOOTSY....I'll try that and see if that works. If not, I'll be back!
#12 | |
Let it warm up at idle with the rad cap off. so air can escape. IF you suspect leaks afterwards. take to a shop and have it pressure tested.
1986 Mustang GT t-top time piece! |
